Velocity of receding galaxies. Hubble <-> scale factor
In summary: So, the recession velocity of a galaxy is essentially H*D. And yes, Hubble's law is a consequence of the cosmological principle which states that the universe is homogeneous and isotropic on large scales.In summary, the conversation discussed the contradiction between the scale factor and Hubble's law in describing the expansion of the universe. It was clarified that a'(t) is not constant and therefore, the recession speed of a galaxy d'(t) is not constant. The concept of comoving distance was also introduced, explaining that d' will increase as the comoving distance d0 increases. Hubble's law was also explained to be a consequence of the cosmological principle, stating that the universe is homogeneous and isotropic on large scales
pensivesnail
Hi there,
This is my first post but I've been a spectator for a long time now. So I've been working on some of the basics of cosmic expansion and there is one contradiction that I came upon that I can't seem to resolve. I've looked around some of the similar threads but I couldn't find anything satisfying so I'll ask myself.
If the expansion of the universe can be described using the scale factor as d(t)=d0*a(t) then by differentiating I find that d'(t)=d0*a'(t) (I'm just following http://en.wikipedia.org/wiki/Scale_factor_(cosmology)).
So this tells me that if a'(t)=const (as was thought to be the fact before the discovery of accelerating expansion) then the recession speed of a galaxy d'(t) should be constant, right?
But if I know look at Hubble's law (which I can even derive from the formula for d(t)) I find that d'(t)=a'(t)/a(t)*d(t)=H*d(t) or simply v=H*D. So doesn't this mean that as the distance becomes greater the speed also becomes greater. So the galaxy is accelerating. Somehow these two expressions must be consistent. What's up?!
I'd be grateful for any help
Space news on Phys.org
pensivesnail said:
Hi there,
The expressions are consistent. Note that d(t) = d0*a(t). If a'(t) is constant, neither a(t) or d(t) are and since H = a'/a, H is not constant either (it is a constant function divided by one that depends on time).
Edit: Let me also add that a' never was thought to be constant. Even for a radiation or matter dominated universe, it depends on time. However, in these cases you have a decelerated expansion instead.
Thanks for the answer. I see what you're saying but I still don't know how to answer the question. The gist of it is: Disregarding accelerated expansion is the recession velocity of a galaxy increasing or not? Does it remain constant? I understand Hubble's law v=H*D to tell me that it is as v will increase as D increases.
Contrarily the formula d'(t)=v=d0*a'(t) seems to say that the recession speed v of a galaxy remains constant (for the case where we disregard what you said in the edit).
d' will still increase if the comoving distance d0 increases. Also, as I said, a' constant leaves H as a varying quantity, you will end up with the same result for d' regardless of what formula you use. Hubbles law with H constant also only holds for relatively nearby objects. H has been varying throughout the history of the universe. Also note that d' really is not a velocity in the usual sense, nothing is really moving here but space is getting larger.
No, a'(t) was never constant. During decelerated expansion, [itex]\ddot{a} < 0[/itex] which means that a'(t) is a decreasing function of time. During radiation-dominated expansion early on, [itex]a \sim t^{1/2}[/itex] so [itex]a'(t) \sim t^{-1/2}[/itex]; during matter-dominated expansion, we have [itex]a \sim t^{2/3}[/itex] and so [itex]a'(t) \sim t^{-1/3}[/itex].
We compare galaxies at different distances at a certain time. So, according to Hubble's law double distance means double recession velocity. This can be imagined by watching points on a uniformly expanding rubber band.
Related to Velocity of receding galaxies. Hubble <-> scale factor
1. What is the velocity of receding galaxies?
The velocity of receding galaxies refers to the speed at which galaxies are moving away from each other. This is due to the expansion of the universe and is measured in kilometers per second.
2. How is the velocity of receding galaxies measured?
The velocity of receding galaxies is measured using the redshift of light emitted from the galaxies. This redshift is caused by the Doppler effect, which stretches the wavelength of light as the galaxies move away from each other.
3. What role does the Hubble Constant play in the velocity of receding galaxies?
The Hubble Constant, named after astronomer Edwin Hubble, is a measure of the rate of expansion of the universe. It is used in calculating the velocity of receding galaxies, as the farther a galaxy is from us, the faster it appears to be moving away due to the expansion of space.
4. How does the scale factor relate to the velocity of receding galaxies?
The scale factor is a measure of the size of the universe at a given time. As the universe expands, the scale factor increases and this directly affects the velocity of receding galaxies. The larger the scale factor, the faster the galaxies appear to be moving away from each other.
5. Can the velocity of receding galaxies change over time?
Yes, the velocity of receding galaxies can change over time due to the expansion of the universe. As the universe continues to expand, the velocity of receding galaxies will also increase. However, the rate of change may vary depending on factors such as the amount of matter and energy in the universe.
  • Cosmology
  • Cosmology
  • Cosmology
  • Cosmology
