Velocity of the ball when it hits the ground, limits?
In summary: I tthink I would take the derivative of d(t) and set it equal to 0 to find the...I think I would take the derivative of d(t) and set it equal to 0 to find the maximum height the ball reaches.
Specter
120
[/B]
The path of a baseball relative to the ground can be modeled by the function
##d(t)=−t^2+8t+1##
, where d(t)represents the height of the ball in metres, and t represents time in seconds.
  1. What is the speed of the ball when it hits the ground?
##d(t)=-t^2+8t+1##
Using the quadratic to find the zeros, so I can find at what time the ball hits the ground.
##x=\frac {-b± \sqrt {b^2-4ac}} {2a}##
##x=\frac {-(8)± \sqrt {(8)^2-4(-1)(1)}} {2(-1)}##
x=-0.123 or x=8.123
Time can't be negative, therefore the ball htis the ground at 8.123 seconds.
I'm not sure how to find the velocity though. I thought I could take the first derivative of d(t)=−t2+8t+1 to find it but I couldn't figure it out that way. I think they want me to use limits somehow but I don't really know how.
How do you get the equation of velocity from the equation you were given? try not to change the t and x.
I'm don't know. My teacher said to use the time that I got for when the ball hits the ground (x=8.123) and limits to solve for the velocity and I'm not sure how to do that.
Although the answer is correct, it is associated to the wrong variable. The function you are given is distance as a function of time. IOW, the independent variable here is t (time). Hence, the variable x in the quadratic equation above should be replace by t.
You were correct in taking the derivative of the given function since velocity is defined as what?
Think of what you have so far and what you can do with the clue.
Isn't velocity just the first derivative of a function with respect to time? I could take the derivative of the function and then subsitute in t= 8.123? This seems like an easier way to do it instead of using limits.
##d(t)=-t^2+8t+1##
##d'(t)+-2t+8##
##v(t)=d'(t)##
##v(t)=-2(8.123)+8##
##=-8.246## m/s
If this is correct, is there another way to solve it using limit formula?
##d(t)=-t^2+8t+1##
##d'(t)+-2t+8##
##v(t)=d'(t)##
##=-8.246## m/s
Use the definition of a derivative. What is it?
This is a good place to understand the definition of a derivative.
Likes Specter
##f'(x)=\frac {lim}{h→0} \frac {f(x+h)-f(x)} {h}##
Wasn't sure how to format the limit correctly with latex.
So i'd just use this and get the answer f'(x)=-2t+8, plug in my value for time when the ball hits the ground and then I have the velocity.
yup!. why is the velocity negative? This is also something to ponder.
Would it have something to do with the direction of the ball?
Yes. That is the reason. Remember that gravity is acting on the ball. Hence, the ball is traveling in the townward direction when v is negative. One more thing. A common question that can be asked is the following. Find the maximum height the ball reaches. How would you do this?
I tthink I would take the derivative of d(t) and set it equal to 0 to find the maximum.
Yes. You find the time t when velocity is 0, then substitute this value of t into the position function. I assume you are taking Calculus 1? This is a very common question that can be asked on a quiz or even a test.
Likes Specter
MidgetDwarf said:
Yes. I assume you are taking Calculus 1? This is a very common question that can be asked on a quiz or even a test.
I guess it would be calculus 1. I'm taking this course online because I never took calc in high school and now I want to go to university and the program I'm interested in requires a calc credit in grade 12. Thanks for the help, I don't have a teacher to go to as everything is done online so people like you help a lot.
NP. Are you using a book to learn from?
I'm actually on the last unit and my exam is next week haha. I've been learning from the lessons the school provides online and youtube videos and some khan academy.
Although you may be getting some idea of calculus. Video lectures are not sufficient enough in regards to learning a subject. They are a supplement. I suggest you purchase a book or 2 on Calculus.
https://www.amazon.com/dp/B00GMPZBGA/?tag=pfamazon01-20
This is an older edition of Thomas Calculus and a really beautiful book. It is of the computation variety, unlike Spivak and Apostol, but it develops the ideas of calculus really well. MathWonk has written an extensive review on this book. Highly recommend, especially for self study.
https://www.amazon.com/dp/B000L3UO2A/?tag=pfamazon01-20
Calculus book by Moise. A first rate mathematician. It similar to Courant calculus, but a tad easier. Great balance between application and theory. This will prepare you to read an Analysis text such as Rudin.
I suggest you read and work from Thomas, and dip into Moise.
Likes Specter
https://www.amazon.com/Calculus-Analytic-Geometry-George-Thomas/dp/B00GMPZBGA?crid=OYRR9TQK4C6J&keywords=calculus+and+analytic+geometry+thomas&qid=1547686943&sprefix=thomas+calculus+with+ana,aps,213&sr=8-3&ref=sr_1_3
https://www.amazon.com/Calculus-complete-Edwin-Moise/dp/B000L3UO2A?crid=VM7GRK1IO4ON&keywords=moise+calculus&qid=1547687173&sprefix=moise+calcul,aps,264&sr=8-1-spell&ref=sr_1_1
Thank you! I'll take a look at those!
##d(t)=-t^2+8t+1##
##d'(t)+-2t+8##
##v(t)=d'(t)##
##=-8.246## m/s
You ARE using limits here! The derivative is defined as a particular kind of limit. Just look in any calculus textbook (or, if you do not have a textbook, look on-line under the key words "derivative" or "velocity").
FAQ: Velocity of the ball when it hits the ground, limits?
What is the velocity of the ball when it hits the ground?
The velocity of the ball when it hits the ground depends on several factors such as the initial velocity, the angle at which it is thrown, and the effects of air resistance. It can be calculated using the equation v = u + at, where v is the final velocity, u is the initial velocity, a is the acceleration due to gravity, and t is the time taken for the ball to hit the ground.
Is there a limit to the velocity of the ball when it hits the ground?
Yes, there is a limit to the velocity of the ball when it hits the ground. This limit is known as the terminal velocity and is reached when the force of air resistance on the ball is equal to the force of gravity pulling it down. At this point, the ball will stop accelerating and will fall at a constant velocity.
How does the mass of the ball affect its velocity when it hits the ground?
The mass of the ball does not affect its velocity when it hits the ground. In the absence of air resistance, all objects will fall towards the ground with the same acceleration due to gravity regardless of their mass. However, the mass of the ball can affect its terminal velocity due to the effects of air resistance.
Can the velocity of the ball when it hits the ground be greater than its initial velocity?
No, the velocity of the ball when it hits the ground cannot be greater than its initial velocity. This is because the acceleration due to gravity always acts in the opposite direction of the initial velocity, causing the ball to slow down as it falls. However, the velocity can be equal to the initial velocity if the ball is thrown straight up and falls back to the ground without any air resistance.
How does the angle at which the ball is thrown affect its velocity when it hits the ground?
The angle at which the ball is thrown can affect its velocity when it hits the ground. When the ball is thrown at an angle, its initial velocity is divided into horizontal and vertical components. The vertical component will determine how high the ball will go before falling back to the ground, while the horizontal component will affect the distance the ball travels before hitting the ground. The velocity when it hits the ground will depend on the combination of these two components.
