Velocity, Period, and Transverse Wave
In summary, the combined string of length 3L, made from three pieces of string of length L joined end-to-end, with masses per unit length of mu_1, mu_1*4.00, and mu_1/4.00, respectively, and under tension F, will take a transverse wave a total time of (7L/2)*sqrt(mu_1/F) to traverse. The correct factor is found by adding the individual times for each piece of string.
Soaring Crane
469
Three pieces of string, each of length L, are joined together end-to-end, to make a combined string of length . The first piece of string has mass per unit length mu_1, the second piece has mass per unit length mu_1*4.00 , and the third piece has mass per unit length mu_1/4.00. If the combined string is under tension F, how much time does it take a transverse wave to travel the entire length 3L? Give your answer in terms of F, mu_1, and L.
v = sqrt(F/mu)
T = position/velocity = 3L/v ??
The answer is (7L/2)*sqrt(mu_1/F).
I understand the sqrt portion, but I am having difficulty with the multiplicative factor.
I thought the velocity would be:
v = sqrt(F/mu_total), where mu_total = mu_1 + 4*mu_1 + .25*mu_1 = 5.25*mu_1
T = 3L/sqrt(F/5.25*mu_1) = 3L*sqrt(5.25)*sqrt(mu_1/F)
How do I get the correct factor?
Thanks.
The densities do not add. You need to find an expression for the time it takes for the wave to traverse each part of the string and add those to find the total time.
I would first commend the student for their attempt at solving the problem and for asking for assistance when they encountered difficulty. I would also point out that their equations and approach are generally correct.
To get the correct factor, the student needs to consider the mass per unit length of each piece of string. The first piece has a mass per unit length of mu_1, the second has a mass per unit length of 4*mu_1, and the third has a mass per unit length of mu_1/4. When these three pieces are joined together, the total mass per unit length of the combined string is:
mu_total = mu_1 + 4*mu_1 + mu_1/4 = 5.25*mu_1
This means that the velocity of the wave can be calculated as:
v = sqrt(F/mu_total) = sqrt(F/5.25*mu_1)
To find the time it takes for the wave to travel the entire length 3L, we can use the equation T = position/velocity. In this case, the position is 3L and the velocity is sqrt(F/5.25*mu_1), so the time is:
T = 3L/sqrt(F/5.25*mu_1) = (3L*sqrt(5.25))/sqrt(F/mu_1) = (3L*sqrt(5.25))*sqrt(mu_1/F)
Thus, the correct factor is (3L*sqrt(5.25)), which gives us the final answer of:
T = (3L*sqrt(5.25))*sqrt(mu_1/F) = (7L/2)*sqrt(mu_1/F)
In summary, the correct factor takes into account the mass per unit length of each piece of string, which affects the velocity of the wave and ultimately the time it takes for the wave to travel the entire length 3L.
Related to Velocity, Period, and Transverse Wave
1. What is velocity in relation to waves?
Velocity is the speed at which a wave travels through a medium. It is typically measured in meters per second (m/s) and is influenced by factors such as the properties of the medium and the frequency of the wave.
2. How is period related to frequency?
Period and frequency are inversely related in waves. Period is the time it takes for one complete cycle of a wave to occur, measured in seconds (s). Frequency is the number of cycles that occur in one second, measured in hertz (Hz). The higher the frequency, the shorter the period, and vice versa.
3. What is a transverse wave?
A transverse wave is a type of wave in which the particles of the medium vibrate perpendicular to the direction of the wave's motion. Examples of transverse waves include light waves and electromagnetic waves.
4. How is wavelength related to velocity and frequency?
Wavelength is the distance between two consecutive peaks or troughs of a wave. It is inversely related to both velocity and frequency. This means that as velocity or frequency increases, the wavelength decreases.
5. Can the velocity of a wave change?
Yes, the velocity of a wave can change depending on the properties of the medium it is traveling through. For example, the velocity of sound waves is faster in solids than in liquids or gases. Additionally, the velocity of a wave can be affected by external factors such as temperature or pressure.
9K
