Velocity translating into weight?
In summary: If you could arrange to only produce matter and antimatter, you could get all the energy back very easily!In summary, when objects are accelerated to high speeds, they gain more mass and therefore weight due to the increase in kinetic energy. This is a fundamental concept in relativity. Matter and antimatter can be created from pure energy, and when they recombine, the energy is released in the form of particles and can be fully recovered.
BuddyPal
I accidentally posted this under another forum user's topic, sorry about that :frown:
My question was regarding matter gaining mass when it is accelerated. My question originated from an explanation of the large hadron collider; the explanation stated that when the protons in the LHC are sped up to 99.9% the speed of light, instead of gaining more speed, they get heavier. Someone posted that everything gains mass when it is accelerated, but there is no significant change until near light speed. How does this added energy translate into weight? The particles themselves are only individual protons, how does one proton gain weight, and where does that weight come from? I'm completely in the dark about this, so if my question doesn't make sense, please set me straight, thank you.
I also heard it mentioned that matter and anti matter can be created with just energy, how?? What form does the matter and anti matter take? When/if they recombine, does it generate the same amount of energy that was required to create it, or are there byproducts of the whole anomaly?
Increases speed means increased energy and energy has mass: e= mc2.
Note that, since speed must be measured relative to some "stationary" frame of reference, the increase in mass is also relative to that frame of reference. If you were moving along side the proton at 99.9% the speed of light, you would not measure any increase in the mass of the proton.
That's not exactly right: they do get more speed, and objects with more speed have more mass, so they also get heavier (from our point of view, at least).
The mass comes from the increased speed! This is just a fact in relativity. Energy and mass are the same stuff, so making something move faster gives it more kinetic energy and therefore more mass, since they're the same stuff. When someone says "the mass of a proton is (some standard number)" they are referring to the mass of a proton at rest. Since kinetic energy is a form of mass too, the weight is different if you "weigh" it while it's moving!
"How" is a big question... there's a whole area of physics there. But one example is a collision between particles in a particle collider. Energy becomes matter there.
Any form that is consistent with the laws of physics. One collision might get you some mesons, and another might get you a handful of other weird particles, like muons and whatnot. As long as all the relevant laws, like conservation of energy and conservation of momentum are satisfied, just about any random particles can be produced.
Always!
Of course, a particle collision doesn't usually produce just matter and antimatter, it also produces a lot of pure energy particles like photons.
FAQ: Velocity translating into weight?
How does velocity affect weight?
Velocity does not directly affect weight. Weight is a measure of the force of gravity on an object, while velocity is a measure of the speed and direction of an object's movement. However, changes in velocity can indirectly affect weight by changing an object's position and distance from the center of gravity of a larger body, such as the Earth.
Can an object's weight change with its velocity?
No, an object's weight does not change with its velocity. Weight is a constant measurement of the force of gravity on an object, regardless of its velocity. However, the perceived weight of an object may change if it is in motion due to factors such as acceleration or air resistance.
Is there a relationship between velocity and weight?
There is no direct relationship between velocity and weight. However, an object's velocity can indirectly affect its weight by influencing factors such as air resistance and gravitational pull.
Does weight increase with velocity?
No, weight does not increase with velocity. As mentioned before, weight is a measure of the force of gravity on an object, and this force does not change with velocity. However, an object's perceived weight may change due to changes in velocity and other external factors.
Is there a maximum velocity at which weight becomes zero?
No, there is no maximum velocity at which weight becomes zero. Weight is a constant measure of the force of gravity on an object, and this force does not become zero at any velocity. However, at extremely high velocities, an object may experience weightlessness due to the lack of external forces acting on it, but this does not mean that its weight has become zero.
