Velocity with respect to arclength is a unit tangent vector?
In summary: A unit tangent vector is a vector that has magnitude 1 at every point, and its direction is always perpendicular to the direction of motion. Suppose you have a curve that you are following, and you measure the distance, ds, that your object has traveled in a given time, t. The distance is proportional to the magnitude of the velocity vector, |v(t)|.
Aldnoahz
37
Hi all,
I have long had this unsolved question about arclength parameterization in my head and I just can't bend my head around it. I seem not to be able to understand why velocity with arclength as the parameter is automatically a unit tangent vector. My professor proved in class that
s(s) = s = ∫ ||v(s)|| ds with lower and upper bound so and s1
He said that by fundamental theorem of calculus, ds/ds = 1 = ||v(s)||, so the velocity vector with respect to arclength s is always a unit tangent vector.
I understand the mathematical proof the professor did but I really need an intuitive explanation. I have thought about this situation where velocity is represented by distance in one dimension, but it seems that it is not always the case that V(s) will be unit speed. Then why is it the case when velocity is parameterized in terms of arclength so that the speed automatically becomes 1?
i do not know but how you define velocity with respect to arc length becomes important
if you are looking at a length -one dimension then the rate of change of displacement will be velocity...the length taken is of some curve but perhaps now one has to forget about the curve- i.e. a two dimensional displacement.
the observer does not know he is moving on a curve...its my common sense response... may be wrong!
Suppose the path was parameterized by the variable t=time. As an object moves along a path, its velocity vector is always tangent to the path it is following. Also, the distance, ds, that it covers in time dt, on the path is instantaneously proportional to the magnitude of the velocity vector.
Now suppose that the path is parameterized by the arc length, s, so the "velocity" with respect to s has magnitude 1. My only concern is that it seems like a strange thing to call a velocity.
Likes drvrm
Hi FactChekcer, I don't seem to understand the logic leap you made between
and
What I want to understand is what happens when you set arclength as the parameter and why
At any point along the curve, the magnitude of velocity is telling you how fast the point is moving in the direction of the path, adding to s(t). So |v(t)| = ds/dt
That is one of the basic tenets of classical differential geometry (start with https://en.wikipedia.org/wiki/Torsion_of_a_curve).
Related to Velocity with respect to arclength is a unit tangent vector?
1. What is the definition of velocity with respect to arclength?
Velocity with respect to arclength is a measure of how quickly an object is changing its position along a curve, per unit of arclength.
2. How is velocity with respect to arclength different from regular velocity?
Regular velocity measures how quickly an object is changing its position over time, while velocity with respect to arclength measures how quickly an object is changing its position along a curve, regardless of time.
3. Why is velocity with respect to arclength useful in physics?
Velocity with respect to arclength is useful in physics because it allows us to analyze the motion of objects along curved paths, such as circular motion or motion along a curved track.
4. How is velocity with respect to arclength calculated?
Velocity with respect to arclength is calculated by taking the derivative of the position vector with respect to arclength. This will give us a unit vector that represents the direction and magnitude of the velocity at any point along the curve.
5. What is the significance of the unit tangent vector in velocity with respect to arclength?
The unit tangent vector in velocity with respect to arclength represents the direction of motion along the curve. It is a unit vector, meaning it has a magnitude of 1, and points in the direction of the curve's tangent at any given point. This allows us to easily analyze the direction and magnitude of an object's velocity at any point along the curve.
  • Differential Geometry
