Calculating Gravity and Mass on Venus: Solve for the Sun's Mass
In summary: So it should be:[(4.88x10^24 kg/5.98x10^24 kg)*(6.38x10^6 m/6.06x10^6 m)^2]*9.81 = 7.22 m/s^2In summary, the mass of Venus is 81.5% that of the Earth, and its radius is 94.9% that of the Earth. Using the ratios of mass and radius, the acceleration due to gravity on the surface of Venus is calculated to be approximately 7.22 m/s^2. The mass of the Sun can also be calculated using the radius and period of Venus' orbit.
MAPgirl23
65
1. The mass of Venus is 81.5% that of the earth, and its radius is 94.9% that of the earth.
Compute the acceleration due to gravity on the surface of Venus from these data.
What is the weight of a 5.00-kg rock on the surface of Venus?
2. Venus orbits the sun in a nearly circular orbit. The radius of the orbit of Venus is 1.08x10^11 m, the period of Venus is 224.7 days(1.94 x 10^7 s)
Calculate the mass of the sun.
** I know F_grav = m * g and F_grav = GM_Earth*m/d^2
M_Earth = 5.98 x 10^24 kg and R_Earth = 6.38 x 10^6 m
I conclude: M_Venus = 4.88x10^24 kg and R_Venus = 6.06 x 10^6 m
Please help. I'm stuck
It's not necessary and probably not a good idea to calculate the mass and radius of Venus! Instead use ratios.
Basic gravity formula: [tex]F= \frac{GmM}{r^2}[/tex] where G is the "universal" gravitational constant, M the mass of the planet, m the mass of the falling object, and r is the radius of the planet. Since mg= F, [tex]g= \frac{GM}{r^2}[/tex].
In particular, for the Earth [tex]g_e= 9.81 m/s^2= \frac{GM_e}{r_e^2}[/tex] and for Venus [tex]g_v= \frac{GM_v}{r_v^2}[/tex].
Divide the second equation by the first and the "G" terms cancel:
[tex]\frac{g_v}{9.81}= \frac{M_v}{M_e}\left(\frac{r_e}{r_v}\right)^2[/tex]. You are given those ratios.
but I did: g_v = [(M_v*r_v^2)/(M_e*r_e)]*9.81 = 4.60 x 10^7 m/s^2
what did I do wrong?
oh, I see now
but I did [(M_v*M_e)/(r_v*r_e)^2]*9.81 = 7.22 m/s^2 what did I do wrong?
Check the units in that [].They don't match.
Daniel.
[(M_v/M_e)*(r_v*r_e)^2]*9.81 = 7.22 m/s^2
[(4.88x10^24 kg/5.98x10^24 kg)*(6.06x10^6 m*6.38x10^6 m)^2]*9.81 = 7.22 m/s^2
sorry it was [(4.88x10^24 kg/5.98x10^24 kg)*(6.06x10^6 m/6.38x10^6 m)^2]*9.81 = 7.22 m/s^2
that got me 0.816 * 0.902 * 9.81 = 7.22
The problem is in the bold part:
You are dividing Venus' radius by the Earth's radius, and you should be dividing the Earth's radius by Venus' radius.
Related to Calculating Gravity and Mass on Venus: Solve for the Sun's Mass
1. What is the formula for calculating gravity on Venus?
The formula for calculating gravity on Venus is: G = (Mm)/r^2, where G is the gravitational constant, M is the mass of Venus, m is the mass of the object, and r is the distance between the object and Venus.
2. How do you calculate the mass of Venus?
The mass of Venus can be calculated using the formula: M = (r^2 x G)/g, where M is the mass of Venus, r is the radius of Venus, G is the gravitational constant, and g is the acceleration due to gravity on Venus.
3. What is the value of the gravitational constant (G)?
The value of the gravitational constant is 6.674 x 10^-11 Nm^2/kg^2. This value is the same for all objects in the universe and is an important factor in calculating gravity and mass.
4. How does the mass of the Sun affect the gravity on Venus?
The mass of the Sun is a major factor in the gravity on Venus. The greater the mass of the Sun, the stronger the gravitational pull it exerts on Venus, which in turn affects the gravity and mass of objects on Venus.
5. How can I use the calculations for gravity and mass on Venus to solve for the Sun's mass?
By using the formula: M = (r^2 x G)/g, where M is the mass of the Sun, r is the distance between the Sun and Venus, and g is the acceleration due to gravity on Venus, you can solve for the Sun's mass. However, this calculation will also require the known values for the mass and radius of Venus.
13K
19K
