Venus during the day, a test of relativity?
In summary, the experiment to test relativity would not work because Venus is in the way, but it's possible to do a demonstration using distant stars.
Vast
285
At the moment you can easily see Venus at any time during the day with a small set of binoculars, or even with the naked eye if you look closely enough and know where to look-around about 31 degrees away from the sun. I was thinking about the experiment to test relativity, where starlight was bent by the suns gravity during an eclipse, and wondered whether Venus could be used in the same manner. Mind you, the glare from the sun, increases the closer it is, and for this experiment to work, Venus needs to be on the other side of the sun to us, and consequently reduces in brightness. Nonetheless, with a modest telescope, wouldn’t one still be able to conduct this experiment?
In principle, yes, but in practice not with a modest telescope because of the sun's glare. (There are of course serious safety issues around telescopic observations of the sun as well).
Eddington did this in 1919, but it required sending an expedition to the southern hemisphere to catch a solar eclipse to eliminate the glare - and then he used distant stars instead of Venus because that's what was behind the sun at the time of the eclipse.
It's more practical to look for distant galaxies distorting the light from even more distant objects (google for "gravitational lensing") but that is most certainly not a job for a modest telescope.
He used the particular distant stars that were behind the Sun at the time of eclipse, but that's not the only reason he used distant stars. He used distant stars because their position on the sky relative to each other does not change over a period of six months or so, so he could measure their position on the sky six months before or after the eclipse, and then measure it again during the eclipse, and compare the two. That won't work with a planet like Venus because its position on the sky does change on a shorter timescale than six months.
Likes Nugatory
The position does change, but we know enough about planetary motion to be calculate where Venus "ought" to be at the time of the eclipse... the analysis would be somewhat analogous to the way that Romer was able to estimate the speed of light from the eclipses of Jupiter's moon Io.
But of course this is all beside the point because Venus wasn't in the right place, and even if it were it's not obvious that the calculation would be any easier than the fixed star one.
I could see doing this as a demonstration if light bending by the Sun is already accepted. But I'm not sure it would be a valid test of that theoretical prediction if it were not already accepted.
The deflection is at most 1.75 arcseconds if Venus is just in the right place, or 900 km at the orbit of Venus. With radar astronomy it is easy to measure and predict its place that good, but with the methods of 1919? In addition the deflection is less than the size of Venus: You have to resolve its disk and measure its geometrical center or something similar.
To answer this objection, one could measure the apparent speed of Venus compared to distant stars as it approached the Sun's limb. Because light deflection means you can see it when naive ray tracing would suggest it's behind the Sun its apparent speed must dip before it passes behind the Sun and pick up again after it emerges. You would not expect this behaviour in a transit.
As noted by others, the precision needed is beyond casual observation.
I'm not sure this will work because the light from the distant stars will be bent as well. But I have not done the math.
If this worked, it wouldn't be a "dip" so much as a gradual decrease, then a gradual increase. The light bending changes smoothly as a function of angle--with radio waves it has been measured, IIRC, for angles as far as 90 degrees away from the Sun.
Gaia has to take it into account with visible light. It looks away from the Sun but the deflection is still a few milliarcseconds while it measures star positions with an uncertainty of several microarceconds.
Related to Venus during the day, a test of relativity?
1. What is the significance of studying Venus during the day?
Studying Venus during the day allows scientists to observe the planet's atmosphere and surface at a different angle than during nighttime observations. This can provide new insights and data about the planet's composition and behavior.
2. How does studying Venus during the day test relativity?
Venus' proximity to the Sun and its strong gravitational pull make it an ideal location to test Einstein's theory of relativity. By observing the planet's orbit and any deviations from predicted patterns, scientists can gather evidence for the accuracy of the theory.
3. What methods are used to study Venus during the day?
Scientists use a variety of techniques to observe Venus during the day, including spectroscopy, radar imaging, and optical telescopes. Each method provides different types of data and can help to paint a more complete picture of the planet.
4. What have we learned about the planet Venus through these studies?
Through studying Venus during the day, scientists have learned about the planet's thick atmosphere, extreme temperatures, and surface features such as mountains and volcanoes. They have also been able to gather data on the planet's rotation and orbit, providing valuable insights into its behavior and evolution.
5. How does studying Venus during the day contribute to our understanding of the universe?
Studying Venus during the day not only helps us to better understand this neighboring planet, but it also contributes to our understanding of the universe as a whole. By testing the principles of relativity, scientists can gain a deeper understanding of the fundamental laws that govern our universe.
