Veracity of Simple Molecular Model
In summary, the conversation discusses the use of models in physics for theoretical convenience. The model of treating atoms as point masses connected by springs is accurate for large systems and high temperatures, but may break down when quantum effects become important. The model is commonly used in thermal physics and is a good description for gases, as long as interactions between molecules are not taken into account.
Bashyboy
1,421
Hello Everyone,
I understand that sometimes in physics we make a model of some physical system purely for theoretical convenience, as it allows us to calculate certain properties of the system very easily; although, sometimes these models aren't actually what is going on, but it doesn't matter, so long as the model accurately predicts the effects.
In the given link http://www.phy.duke.edu/~lee/P53/therm2.pdf , they suppose such a model. Here is what they say:
"To be able to count the degrees of freedom we must make a model of the molecule. We
will treat the atoms as point masses, and imagine that the bonds between atoms are like
stiff springs connecting these masses."
How accurate is this model, and when does it begin to break down?
It works pretty well so long as quantum effects are not important. This most often means big systems (##\sim N_\mathrm{A}##) and high temperatures. Basically, you want the difference between consecutive energy levels to be small compared to ##k_\mathrm{B} T##, and that the probability of a single quantum state to be populated to be ##\ll 1##.
If you want to know more, you should look into statistical physics. An introductory course will cover quantum statistics and the classical limit.
Likes 1 person
So, would it be safe to say, that this model will probably work in almost all cases in which someone uses thermal physics?
I actually just began such a course. But I believe we won't be covering those topics for some time.
Yes. For a gas, so long as you don't start doing things like laser cooling, that model is a pretty good description. Deviations from the ideal gas law due to interactions between molecules will kick in much before that model of point masses and springs is no longer valid.
Likes 1 person
I can say that the simple molecular model described in the given link is a commonly used and accepted model in physics. It is a simplified representation of a complex system, and as mentioned, it is used for theoretical convenience. However, like any model, it has its limitations and may not accurately represent the actual system in all cases.
The accuracy of this model depends on the specific system being studied and the level of detail required for the calculations. In some cases, this model may accurately predict the behavior of the system, while in others, it may fail to capture all the complexities and nuances of the actual system.
One of the major limitations of this model is that it assumes that atoms are point masses and the bonds between them are rigid springs. In reality, atoms have a finite size and bonds can exhibit flexibility and deformability. This model may also not take into account the effects of other forces such as Van der Waals interactions or hydrogen bonding, which can significantly affect the behavior of a molecule.
In conclusion, while the simple molecular model described in the given link may be a useful tool for calculations, it is important to understand its limitations and when it may break down. As scientists, we must constantly evaluate and improve our models to better understand the complexities of the physical world.
FAQ: Veracity of Simple Molecular Model
1. What is a simple molecular model?
A simple molecular model is a representation of a molecule using simplified diagrams or physical models. These models are used to illustrate the structural and chemical properties of molecules and their interactions with other molecules.
2. How accurate are simple molecular models?
The accuracy of a simple molecular model depends on the level of simplification used. While they may not be as precise as more complex models, simple molecular models can still provide valuable insights and predictions about the behavior of molecules.
3. What are the benefits of using simple molecular models?
Simple molecular models are useful tools for visualizing and understanding the structure and behavior of molecules. They are often more accessible and easier to interpret than more complex models, making them valuable for teaching and communication purposes.
4. How do scientists ensure the veracity of simple molecular models?
Scientists use a variety of techniques to validate the accuracy of simple molecular models, such as comparing their predictions to experimental data, conducting simulations and calculations, and refining the model based on new evidence.
5. Can simple molecular models be used to study all types of molecules?
Simple molecular models are most commonly used for small, simple molecules. However, with advancements in technology, they can also be applied to larger and more complex molecules, although their accuracy may be limited in these cases.
