Verification of Green's Theorem
In summary, the students were trying to find the equation for the region bounded by the curves y= x^2 and y2= x, but they made several errors. One was that they only integrated half way around the boundary- from (0, 0) to (1, 1) along the curve y= x^2. They still need to integrate from (1, 1) back to (0, 0) along the curve x= y^2. And the integration over the region bounded by those is NOT \int_0^1\int_0^1 dydx. To integrate over the given region, if you wish to use the order "dydx" then, yes, x goes form 0 to
sunnyday11
Verify Green's Theorem for F(x,y) = (2xy-x2) i + (x + y2) j
and the region R which is bounded by the curves y = x2 and y2 = x
[tex]\int[/tex] CF dr = [tex]\int\int[/tex]R (dF2/dx - dF1/dy) dxdy
For [tex]\int[/tex] CF dr ,
r(t) = x i + x2 j
r'(t) = i + 2x j
0 to 1 [tex]\int[/tex] (2x3 + x2 + 2x5)dx
= 2/4 + 1/3 + 2/6
= 7/6
For [tex]\int\int[/tex]R (dF2/dx - dF1/dy) dxdy both integrate from 0 to 1.
[tex]\int\int[/tex] (1 - 2x) dxdy = [tex]\int[/tex] (1- 2x)dx = 1-1 = 0
I think I have made an error somewhere but I could not figure out where.
Thank you very much!
There are several errors. First, you have only integrated half way around the boundary- from (0, 0) to (1, 1) along the curve [itex]y= x^2[/itex]. You still need to integrate from (1, 1) back to (0, 0) along the curve [itex]x= y^2[/itex].
[tex]\int_0^1\int_0^1 dydx[/tex]
That is over the square with boundaries y= 0, y= 1, x= 0, x= 1. To integrate over the given region, if you wish to use the order "dydx" then, yes, x goes form 0 to 1 but for every x, y goes from [itex]x^2[/itex] to [itex]\sqrt{x}[/itex]:
[tex]\int_{x=0}^1\int_{y= x^2}^{\sqrt{x}} dydx[/tex]
Or you can use the order dxdy. Then y goes from 0 to 1 while x goes from [itex]y^2[/itex] to [itex]\sqrt{y}[/itex]:
[tex]\int_{y=0}^1\int_{x= y^2}^{\sqrt{y}} dxdy[/tex]
And also be more precise in your notation. Don't use x for your parameter when that is already a variable in the original vector field. It makes no sense to write r(t) = x i + x^2 j unless x is a function of t but then you write x(t) instead of just x. Good notation is always best to solve a problem.
Thank you very much for your help!
I got 1/15 for both parts, so I just subtracted one from the other and got 0 which agrees with the other solution.
FAQ: Verification of Green's Theorem
What is Green's Theorem?
Green's Theorem is a mathematical theorem that relates the line integral of a two-dimensional vector field over a closed curve to the double integral of the divergence of the same vector field over the region bounded by the curve.
Why is it important to verify Green's Theorem?
Verification of Green's Theorem is important because it provides a way to check the accuracy of calculations and ensures that the theorem is being applied correctly. It also helps to understand the underlying concepts and principles of the theorem.
How is Green's Theorem verified?
Green's Theorem can be verified by evaluating both the line integral and the double integral over the given curve and region, respectively, and comparing the results. If they are equal, then Green's Theorem is verified.
Can Green's Theorem be applied to any vector field?
No, Green's Theorem can only be applied to a two-dimensional vector field in which the components of the vector field have continuous partial derivatives. This is known as the smoothness condition.
What are some applications of Green's Theorem?
Green's Theorem has various applications in physics, engineering, and other fields. It is used to calculate work done by a force, flux of a vector field, and electric and magnetic fields. It is also used in the solution of differential equations and in the calculation of areas and volumes.
