Verification of stress function
In summary, a stress function is a mathematical function used in solid mechanics to simplify the analysis of stress and strain in complex structures. It must satisfy equilibrium equations and boundary conditions and produce stress values that match experimental or numerical results. Some benefits of using a stress function include simplifying analysis and identifying critical regions of stress. Common stress functions used in engineering include Airy, Westergaard, and Boussinesq functions, but they may only be applicable to certain types of materials with specific symmetries or properties. For example, the Airy function is only valid for isotropic materials while the Westergaard function is applicable to orthotropic materials.
roldy
237
The stress function [itex]\phi(x,y) = \frac{q}{4c^2}\left(c^2xy - cxy^2 - xy^3 + cLy^2 + Ly^3\right)[/itex] is proposed as giving the solution for a cantilever (0 = x < L, -c [itex]\leq[/itex] y [itex]\leq[/itex] c) loaded by uniform shear along the edge y = +c, and stress/traction free along the edge y = -c and x = L.
Check if the stress function actually solves the problem in question.
[itex]\phi(x,y) = c_1x^2 + c_2xy + c_3y^2 + c_4x^3 + c_5x^2y + c_6xy^2 +c_7y^3 + c_8x^4 + c_9x^3y + c_{10}x^2y^2 + c_{11}xy^3 + c_{12}y^4 + c_{13}x^5 + c_{14}x^4y + c_{15}x^3y^2 + c_{16}x^2y^3 + c_{17}xy^4 + c_{18}y^5[/itex]
(1) [itex]\sigma_{xx}=\frac{\partial^2\phi}{\partial y^2}[/itex]
(2) [itex]\sigma_{yy}=\frac{\partial^2\phi}{\partial x^2}[/itex]
(3) [itex]\sigma_{xy}=-\frac{\partial^2\phi}{\partial x \partial y}[/itex]
I'm letting q represent [itex]\sigma_{xy}[/itex]
First I setup the boundary conditions:
@ x = 0
[itex]\sigma_{xx} = unsure[/itex]
[itex]\sigma_{xy} = unsure[/itex]
@ x = L
[itex]\sigma_{xx} = 0[/itex]
[itex]\sigma_{xy} = 0[/itex]
@ y = c
[itex]\sigma_{yy} = 0[/itex]
[itex]\sigma_{xy} = q[/itex]
@ x = -c
Because the loading is symmetric about the y-axis (x = 0), odd powers of x in [itex]\phi(x,y)[/itex] are canceled.
[itex]\phi(x,y) = c_1x^2 + c_3y^2 + c_5x^2y + c_7y^3 + c_8x^4 + c_{10}x^2y^2 + c_{12}y^4 + c_{14}x^4y + c_{16}x^2y^3 + c_{18}y^5[/itex]
Because the loading is not symmetric about the x-axis (y = 0), even powers of y in [itex]\phi(x,y)[/itex] are canceled.
[itex]\phi(x,y) = c_5x^2y + c_7y^3 + c_{14}x^4y + c_{16}x^2y^3 + c_{18}y^5[/itex]
From this new expression for [itex]\phi(x,y)[/itex], I can use (1), (2), and (3) to find the functions for the stresses.
[itex] \sigma_{xx} = 6c_7y + 6c_{16}x^2y + 20c_{18}y^3[/itex]
[itex] \sigma_{yy} = 2c_5y + 12c_{14}x^2y + 2c_{16}y^3[/itex]
[itex] \sigma_{xy} = -2c_5x - 4c_{14}x^3 - 6c_{16}xy^2[/itex]
Now I apply the boundary conditions
@ x = 0
[itex] unsure = \sigma_{xx} = 6c_7y + 20c_{18}y^3[/itex]
[itex] unsure = \sigma_{xy} = ?[/itex]
@ x = L
[itex] 0 = \sigma_{xx} = 6c_7y + 6c_{16}L^2y + 20c_{18}y^3 \Rightarrow 0 = 3c_7 + 3c_{16}L^2 + 10c_{18}y^2[/itex]
[itex] 0 = \sigma_{xy} = -2c_5L - 4c_{14}L^3 - 6c_{16}Ly^3 \Rightarrow 0 = c_5 + 2c_{14}L^2 + 3c_{16}y^3[/itex]
@ y = c
[itex] 0 = \sigma_{yy} = 2c_5c + 12c_{14}x^2c + 2c_{16}c^3 \Rightarrow 0 = c_5 + 6c_{14}x^2 + c_{16}c^2[/itex]
[itex] q = \sigma_{xy} = -2c_5x - 4c_{14}x^3 - 6c_{16}xc^2[/itex]
[itex] qL = F_x = \int \limits^L_0\sigma_{xy}(1)dx = \int \limits^L_0(-2c_5x - 4c_{14}x^3 - 6c_{16}xc^2)(1)dx = -c_5L^2 - c_{14}L^4 - 3c_{16}L^2c^2 \Rightarrow q = -c_5L - c_{14}L^3 - 3c_{16}Lc^2[/itex]
[itex] 1/2qL^2 = M = \int \limits^L_0\sigma_{xy}x(1)dx = \int \limits^L_0(-2c_5x - 4c_{14}x^3 - 6c_{16}xc^2)x(1)dx = -2/3c_5L^3 - 4/5c_{14}L^5 -2 10c_{16}L^3c^2 \Rightarrow q = -4/3c_5L -8/5c_{14}L^3 - c_{16}Lc^2[/itex]
@y = -c
[itex] 0 = \sigma_{yy} = -2c_5c - 12c_{14}x^2c - 2c_{16}c^3 \Rightarrow 0 = c_5 + 6c_{14}x^2 + c_{16}c^2[/itex]
[itex] 0 = \sigma_{xy} = -2c_5x - 4c_{14}x^3 - 6c_{16}x(-c)^2 \Rightarrow 0 = c_5 + 2c_{14}x^2 + 3c_{16}c^2[/itex]
I first need to solve for c5, c14, and c16[/itex] by picking 3 equations with only those terms in it.
I've tried using different combinations of the 3 system of equations to solve for the constants but I'm not getting desired results. The answers are a lot more complicated than they should be when compared to the constants in [itex]phi(x,y)[/itex] given.
My questions:
1) Which 3 equations would be best to select to find c5, c14, and c16?
2) What would be the correct boundary conditions for [itex] \sigma_{xx}[/itex] for x = 0
3) Is the setup correct for the resultant force and moment at y = c?
You seem to be trying to derive the stress function, which is a much more complicated problem (and one you do not seem to be given enough information for in the description) than the one given in the problem statement. You are given a stress function, and you should see if it is a valid stress function, ie. that it describes the problem it is supposed to describe.
You have identified all the boundary conditions for the given data. Calculate the stresses [itex]\sigma_{xx}[/itex], [itex]\sigma_{yy}[/itex], [itex]\sigma_{xy}[/itex] at all the boundaries using the equations (1)-(3), and see if they match. If they do, the stress function solves the problem in question, if they don't, it doesn't.
Likes 1 person
Related to Verification of stress function
1. What is a stress function?
A stress function is a mathematical function used to describe the state of stress at a point in a material. It is typically used in the field of solid mechanics to simplify the analysis of stress and strain in complex structures.
2. How is a stress function verified?
To verify a stress function, it must satisfy the equilibrium equations and boundary conditions for the given material and loading conditions. The function must also produce stress values that match experimental or numerical results.
3. What are the benefits of using a stress function?
Using a stress function can simplify the analysis of stress and strain in complex structures, making it easier to solve for stresses and displacements. It can also help identify critical regions where stress concentrations may occur.
4. What are some common stress functions used in engineering?
Some common stress functions used in engineering include Airy stress function, Westergaard stress function, and Boussinesq stress function. These functions are often used in problems involving plates, beams, and other structures.
5. Can a stress function be used for all types of materials?
No, a stress function may only be applicable to certain types of materials that exhibit certain symmetries or properties. For example, the Airy stress function is only valid for isotropic materials, while the Westergaard stress function is applicable to orthotropic materials.
