Verify that ## N-M ## is divisible by ## 9 ##
  • Thread starter Thread starter Math100
The discussion centers on proving that the difference between a number \( N \) and its digit-reversed counterpart \( M \) is divisible by 9. The proof utilizes the property that \( 10 \equiv 1 \pmod{9} \), leading to the conclusion that \( N - M \equiv 0 \pmod{9} \). Participants also mention the relevance of this property in accounting, specifically the technique known as "casting out nines" for error-checking in calculations. The conversation touches on the educational aspect of this method, noting its diminishing presence in modern teaching. Overall, the mathematical principle remains a useful tool for verifying numerical accuracy.
Math100
Given an integer ## N ##, let ## M ## be the integer formed by reversing the order of the digits of ## N ## (for example, if ## N=6923 ##, then ## M=3296 ##). Verify that ## N-M ## is divisible by ## 9 ##.
None.
Proof:
Suppose ## N=a_{m}10^{m}+\dotsb +a_{2}10^{2}+a_{1}10+a_{0} ##, where ## 0\leq a_{k}\leq 9 ##, be the decimal
expansion of a positive integer ## N ##.
Let ## M=a_{0}10^{m}+\dotsb +a_{m-2}10^{2}+a_{m-1}10+a_{m} ##, where ## 0\leq a_{q}\leq 9 ##, be the
decimal expansion of a positive integer ## M ##.
Then ## N-M=(a_{m}-a_{0})10^{m}+\dotsb +(a_{2}-a_{m-2})10^{2}+(a_{1}-a_{m-1})10+(a_{0}-a_{m}) ##.
Observe that ## 10\equiv 1\pmod {9}\implies 10^{n}\equiv 1\pmod {9} ##.
This means ## 9\mid (10^{n}-1) ##.
Thus ## 9\mid (N-M) ##.
Therefore, ## N-M ## is divisible by ## 9 ##.
Math100 said:
Homework Statement:: Given an integer ## N ##, let ## M ## be the integer formed by reversing the order of the digits of ## N ## (for example, if ## N=6923 ##, then ## M=3296 ##). Verify that ## N-M ## is divisible by ## 9 ##.
Relevant Equations:: None.
Proof:
How?
We have
\begin{align*}
N-M&=(a_{m}-a_{0})10^{m}+\dotsb +(a_{2}-a_{m-2})10^{2}+\ldots +(a_{1}-a_{m-1})10+(a_{0}-a_{m})\\
&\equiv (a_{m}-a_{0})+(a_{m-1}-a_1)+ \dotsb +(a_{2}-a_{m-2}) +(a_{1}-a_{m-1})+(a_{0}-a_{m}) \pmod 9\\
&\equiv 0 \pmod 9
\end{align*}
Sorry, haven't seen it without the extra line.
Likes Delta2 and Math100
I think this is true if you permute any two ( even number?) of digits of the original number.
This is, iirc, a trick used often by accountants: If your final result is a sum is wrong by a multiple of 9, then you flipped your digits in one of the summands.
Likes pbuk
Any permutation will do.
Not so much any more, not sure if they even teach it these days... kids of today... bah, humbug...
Likes Delta2 and WWGD
fresh_42 said:
How?
We have
\begin{align*}
&\equiv 0 \pmod 9
\end{align*}
I can understand your explanation but I can't understand OP: I can't fill in the in between steps, how from ##10^n-1## is a multiple of 9 we derive that N-M is a multiple of 9.
Should be ##10^{m-k} - 10^k##, which is what multiplies ##a_k##.
Likes Delta2
Orodruin said:
Should be ##10^{k} - 10^{m-k}##, which is what multiplies ##a_k##.
Or, in the case of a random perturbation ##\sigma## of the digits:
10^k - 10^{\sigma(k)}.
I'm not sure that was what it was about. The trick I know of, which is called "casting out 9s", had to do with a check on the total of a longish column of numbers.
For each number in the column, add all the digits repeatedly until you get down to a single digit. For example, 4027 --> 4 + 2 + 7 = 4 + 9 = 13 --> 1 + 3 = 4. We could have skipped a couple steps by noticing that 2 + 7 adds to 9, which can be discarded ("cast out") and replaced with zero if necessary. What this does is to show that ##4027 \equiv 4~\mod 9##.
Do the same operation for each number in the column, essentially writing the modulo 9 equivalence class. Then add all the mod 9 numbers, again repeatedly adding to get a single digit.
Compare this digit to what you get when you add the digits of your earlier sum. If there's a discrepancy, it means you've made a mistake somewhere.
As an example:
4027 --> 4 (work shown above)
3195 --> 0 ( after casting out all 9s we're left only with 0)
6211 --> 1
------ The three numbers above add to 5
13434 --> 6
I've deliberately made a mistake in adding my three numbers to get 13,434, which is equiv. to 6 mod 9. The sum of the equivalence classes of the individual numbers is 5. This tells me that I've made a mistake somewhere.
Yeah, the preference seems to be to give kindergarteners a calculator and call it good.
Regarding the problem of this thread, l've found this to be a good parlor trick to show young kids. I ask them to write down, say, a four-digit number, and then write down any permutation of the original number. I then ask them to subtract whichever number is smaller from the larger one.
I then ask if the result has the same number of digits. If so, I ask them to tell me all but one of the digits, with the caveat that if there are any 0s, those need to be told to me. Coming up with the missing digit is simple if all but one of the digits are known.
I did this with my "8 -3/4 year old" niece last summer, and she really got a kick out of it.
Likes jim mcnamara
