docnet
- 460
- Homework Statement
- verify ##u_\delta ## solves the PDE!
- Relevant Equations
- ##\partial_t u-\Delta u=0##
I feel that my reasoning becomes shaky near the conclusion. So, someone should tell me why it is weak, and suggest how to make it stronger. Thanks.
For ##\delta>0## we define the Appell transform of ##u## by $$u_\delta=(1+\delta t)^{-\frac{n}{2}}exp\Big(-\frac{\delta|x|^2}{4(1+\delta t)}\Big)u\Big(\frac{t}{1+\delta t}, \frac{x}{1+\delta t}\Big)$$ Verify that if ##u(t,x)## solves the PDE, then the Appel transform of u also solves it.
We operate on ##u_\delta## with ##\mathcal{L}:=\partial_t-\Delta## after introducing the following shorthand notation
$$\Rightarrow ABC$$
where
$$A=(1+\delta t)^{-\frac{n}{2}}$$
$$B=exp\Big(-\frac{\delta|x|^2}{4(1+\delta t)}\Big)$$
$$C=u\Big(\frac{t}{1+\delta t}, \frac{x}{1+\delta t}\Big)$$
The partial derivatives
$$\partial_t A=-\frac{\delta n}{2(1+\delta t)}A$$
$$\partial_{x_i}A=\partial_{x_i}^2A=0$$
$$\partial_tB=\frac{\delta^2|x|^2}{4(1+\delta t)^2}B$$
$$\partial_{x_i}B=-\frac{\delta x_i}{2(1+\delta t)}B$$
$$\partial_{x_i}^2B=-\frac{\delta}{2(1+\delta t)}B+\frac{\delta^2 x_i^2}{4(1+\delta t)^2}B$$
$$\partial_t C=\partial_tC\partial_t\frac{t}{1+\delta t}+\partial_xC\partial_t\frac{x}{1+\delta t}=\partial_t C \frac{1}{(1+\delta t)^2}-\partial_x C\frac{\delta x}{(1+\delta t)^2}$$
$$\partial_{x_i}C=\partial_{x_i}C\partial_{x_i}\frac{x}{1+\delta t}+\partial_tC\partial_{x_i}\frac{t}{1+\delta t} =\partial_{x_i}C\frac{1}{1+\delta t}$$
$$\partial_{x_i}^2 C=\partial_{x_i}^2C\frac{1}{(a+\delta t)^2}$$
To show ##u_\delta## is also a solution of the heat equation, first we operate on ##u_\delta## with ##\partial_t## using the chain rule
$$\partial_t(ABC)=(B\partial_tA+A\partial_tB)C+AB\partial_tC$$
$$=(B\cdot-\frac{\delta n}{2(1+\delta t)}A+A\frac{\delta^2|x|^2}{4(1+\delta t)^2}B)C+AB(\partial_tC\frac{1}{(1+\delta t)^2}-\partial_x C\frac{\delta x}{(1+\delta t)^2})$$
And then on ##u_\delta## with ##\partial_{x_i}##
$$\partial_{x_i}(ABC)=(B\partial_{x_i}A+A\partial_{x_i}B)C+AB\partial_{x_i}C$$
$$=A\cdot -\frac{\delta x_i}{2(1+\delta t)}BC+AB\partial_{x_i}C\frac{1}{1+\delta t}$$
operate once more using ##\partial_{x_i}##
$$\partial_{x_i}\Big[A\cdot -\frac{\delta x_i}{2(1+\delta t)}BC+AB\partial_{x_i}C\frac{1}{1+\delta t}\Big]$$
$$=\partial_{x_i}(A\cdot -\frac{\delta x_i}{2(1+\delta t)})BC+A\cdot-\frac{\delta x_i}{2(1+\delta t)}\partial_{x_i}(BC)$$$$+\partial_{x_i}(AB)\partial_{x_i}C\frac{1}{1+\delta t}+AB\partial_{x_i}^2C\frac{1}{1+\delta t}$$
$$=(A\cdot\frac{\delta}{2(1+\delta t)}+0\cdot)BC+A\cdot -\frac{\delta x_i}{2(1+\delta t)}(-\frac{\delta x_i}{2(1+\delta t)}BC+B\partial_{x_i}C\frac{1}{1+\delta t})$$
$$+(0\cdot+A\cdot -\frac{\delta x_i}{2(1+\delta t)}B)\partial_{x_i}C\frac{1}{1+\delta t}+AB\partial_{x_i}^2C\frac{1}{(1+\delta t)^2}$$
$$=ABC\frac{\delta}{2(1+\delta t)}+ABC\frac{\delta^2x_i^2}{4(1+\delta t)^2}-AB\partial_{x_i}C\frac{\delta x_i}{2(1+\delta t)^2}$$
$$-AB\partial_{x_i}C\frac{\delta x_i}{2(1+\delta t)^2}+AB\partial_{x_i}^2C\frac{1}{(1+\delta t)^2}$$
sum over i
$$=ABC\frac{\delta n}{2(1+\delta t)}+ABC\frac{\delta^2|x|^2}{4(1+\delta t)^2}-2AB\partial_x C\frac{\delta \sum x_i}{2(1+\delta t)^2}+AB\Delta C\frac{1}{(1+\delta t)^2}$$
compute ##\partial_t u_\delta -\Delta u_\delta##
$$(B\cdot-\frac{\delta n}{2(1+\delta t)}A+A\frac{\delta^2|x|^2}{4(1+\delta t)^2}B)C+AB(\partial_tC\frac{1}{(1+\delta t)^2}-\partial_x C\frac{\delta x}{(1+\delta t)^2})$$$$+ABC\frac{\delta n}{2(1+\delta t)}-ABC\frac{\delta^2|x|^2}{4(1+\delta t)^2}+2AB\partial_x C\frac{\delta \sum x_i}{2(1+\delta t)^2}-AB\Delta C\frac{1}{(1+\delta t)^2}$$
$$=\frac{1}{(1+\delta t)^2}AB\Big[\partial_tC-\Delta C\Big]$$
$$=\frac{1}{(1+\delta t)^2}AB\Big[\partial_tu\Big(\frac{t}{1+\delta t}, \frac{x}{1+\delta t}\Big)-\Delta u\Big(\frac{t}{1+\delta t}, \frac{x}{1+\delta t}\Big)\Big]$$
We make a change of variables using ##t'=\frac{t}{1+\delta t}## and ##x'=\frac{x}{1+\delta t}## and by the heat equation, the terms inside the parenthesis vanish to zero
$$\partial_tu(t',x')-\Delta u(t',x')=0$$
We conclude that if ##u(t',x')## solves the heat equation, ##u_\delta## also solves the heat equation.
$$\Rightarrow ABC$$
where
sum over i
