Verify the Trigonometric Identity
The discussion revolves around verifying two trigonometric identities. For Problem 1, participants explore the expression csc(tan^{-1}(x/2)) and clarify that it simplifies to √((x² + 4)/x) by using a right triangle approach and the Pythagorean theorem. In Problem 2, the identity √((1 - sin x)/(1 + sin x)) = |cos x|/(1 + sin x) is debated, with suggestions to manipulate the left side and apply trigonometric identities. Participants emphasize the importance of correctly applying identities and maintaining proper notation throughout the verification process. The thread concludes with a consensus on the correct forms of the identities and the necessity of careful algebraic manipulation.
FritoTaco
Problem 1
: csc(tan^{-1}\dfrac{x}{2})=\sqrt{\dfrac{x^{2}+4}{x}}
Problem 2: \sqrt{\dfrac{1-sinx}{1+sinx}}=\dfrac{|cosx|}{1+sinx}
Quotient Identities
tan\theta=\dfrac{sin\theta}{cos\theta}
cos\theta=\dfrac{cos\theta}{sin\theta}
Pythagorean Identites
sin^{2}\theta+cos^{2}=1
cot^{2}\theta+1=csc^{2}\theta
tan^{2}+1=sec^{2}\theta
Recirpocal Identites
sin\theta=\dfrac{1}{csc\theta}
cos\theta=\dfrac{1}{sec\theta}
tan\theta=\dfrac{1}{cot\theta}
csc\theta=\dfrac{1}{sin\theta}
sec\theta=\dfrac{1}{cos\theta}
cot\theta=\dfrac{1}{tan\theta}
Cofunction Identities
(maybe useful?)
sin(\dfrac{\pi}{2}-\theta)=cos\theta
cos(\dfrac{\pi}{2}-\theta)=sin\theta
tan(\dfrac{\pi}{2}-\theta)=cot\theta
csc(\dfrac{\pi}{2}-\theta)=sec\theta
sec(\dfrac{\pi}{2}-\theta)=csc\theta
cot(\dfrac{\pi}{2}-\theta)=tan\theta
Note: \sqrt{x^{2}}=|x|
Problem 1: Any ideas on how to get started? I have no idea what to do with inverse tangent and that stupid x/2 and it makes me mad! I know I need some work for it to be a valid thread so here goes nothing.
Maybe manipulate the left side?
csc(cot\theta)
...yup, I'm totally lost.
Problem 2:
I manipulated the left side
\dfrac{\sqrt{1-sinx}}{\sqrt{1+sinx}}\cdot\dfrac{\sqrt{1-sinx}}{\sqrt{1-sinx}}
\dfrac{1-sinx}{\sqrt{(1+sinx)(1-sinx)}}
\dfrac{1-sinx}{\sqrt{(1+sin^{2}x)}} <--\sqrt{x^{2}}=|x|
\dfrac{1-sinx}{|cosx|}
\dfrac{|cosx|}{1+sinx} Am I allowed to just switch it around like that?
\dfrac{|cosx|}{1+sinx} = \dfrac{|cosx|}{1+sinx}
Problem 1: Try drawing a triangle where one of the angles have tan(theta) = x/2 ...
Problem 2: No, you cannot just switch it, you might want to try multiplying denominator and numerator by something different though.
Likes FritoTaco
for 1 use
$$\csc x=\dfrac{\sec x}{\tan x}$$
and
$$\sec ^2 x=1+\tan^2 x$$
for 2 start with
$$\dfrac{|\cos x|}{1+\sin x}=\sqrt{\left(\dfrac{\cos x}{1+\sin x}\right)^2}$$
Likes FritoTaco
Regarding problem 2:
##(1-u)(1+u)=1-u^2\ ## not ##\ 1+u^2\,.##
Therefore, ##\ (1+\sin x)(1-\sin x)\ne 1+\sin^2x\,.##
Likes FritoTaco
@Orodruin, if I draw a triangle, csc is csc\theta=\dfrac{r}{y}, how do I find r? Is it just r=(\sqrt{x^{2}+4})? Which makes it less confusing actually. But still confused because now I have:
(\sqrt{x^{2}+4})=\dfrac{\sqrt{x^{2}+4}}{x}
@lurflurf, How does the numerator become cosx? Doesn't it need to be squared to use the Pythagorean identity in order to change its value?
@SammyS, is that when I was finding the common denominator?
^It is squared I have used
$$|x|=\sqrt{x^2}$$
\left|\dfrac{\cos x}{1+\sin x}\right|=
\sqrt{\left(\dfrac{\cos x}{1+\sin x}\right)^2}=
\sqrt{\dfrac{\cos^2 x}{(1+\sin x)^2}}$$
Likes FritoTaco
I only see one place where you have ##\ (1+\sin x)(1-\sin x)\ ##.
Did you look for that ?
Likes FritoTaco
FritoTaco said:
Problem 1
You can not verify (1) as it is wrong. ##csc(tan^{-1}\dfrac{x}{2})=\dfrac{\sqrt{x^{2}+4}}{x}##
is true.
Likes FritoTaco
@SammyS, Oh. I see, where. I had in the denominator with a (+) sign. Here is what it should look like: \dfrac{1-sinx}{\sqrt{(1-sin^{2}x)}}
@lurflurf, Oh. I see now, is this right?
\sqrt{\left(\dfrac{cosx}{1+sinx} \right)^{2}}
\sqrt{\dfrac{cos^{2}x}{(1+sinx)^{2}}}
\sqrt{\dfrac{1-sin^{2}x}{1+sin^{2}x}}
\sqrt{\dfrac{1-sinx}{1+sinx}}=\sqrt{\dfrac{1-sinx}{1+sinx}}
Is this correct?
Also, for problem 2. I'm confused on how you get cscx=\dfrac{secx}{tanx} Did you use an identity?
@ehild, Oh, that was an editing mistake, my bad. It's csc(tan^{-1}\dfrac{x}{2})=\dfrac{\sqrt{x^2+4}}{x}.
$$\csc x=\frac{1}{\sin x} \\
\csc x=\frac{1}{\sin x}\cdot\frac{\sec x}{1/\cos x} \\
\csc x=\frac{\sec x}{\sin x/\cos x} \\
\csc x=\frac{\sec x}{\tan x}$$
Likes FritoTaco
Oh okay, but how does that get me to a value of 4 which is part of what I need for my end result? I did the triangle like someone previously suggested which worked but I was missing an x in the denominator. Hmmm...
$$|\sec x|=\sqrt{\sec ^2 x}=\sqrt{1+\tan^2 x}$$
Likes FritoTaco
Use the relation ##\sin(\alpha)=\frac{tan(\alpha)}{\sqrt{1+tan^2(\alpha)}}## with ##\alpha=\tan^{-1}(x/2)##
Likes FritoTaco
I figured it out. It was actually easier than I thought...
If you plot the tangent of \dfrac{x}{2} in Quadrant one of a triangle, you just find the hypotenuse using the Pythagorean theorem which is \sqrt{x^{2}+4}. Then find the csc which is csc\theta=\dfrac{hyp}{opp}=\sqrt{\dfrac{x^{2}+4}{x}}. Thanks guys!
It is wrong. x should be outside the square root.
Likes FritoTaco
@ehild, Ahhhhh. Thanks for pointing that out, I keep making that editing mistake. It should be this, csc\theta=\dfrac{hyp}{opp}=\dfrac{\sqrt{x^{2}+4}}{x}
Note: The original problem should have the denominator of 'x' outside the square root. I didn't initially put that in the problem, to begin with.
