MHB Verify Trig Identity: 1+cosx+cos2x=1/2+(sin5/2x)/(2sin1/2x) - Catlover0330
The identity 1 + cos(x) + cos(2x) = 1/2 + (sin(5/2x) / (2sin(1/2x))) is verified through a series of trigonometric transformations. Starting from the left side, it is rewritten using known identities, leading to the expression involving cosines and sines. The right side is manipulated using the triple-angle identity for sine and product-to-sum identities, ultimately simplifying to match the left side. The verification process demonstrates the equality by systematically applying trigonometric identities and algebraic properties. The identity is confirmed as shown.
MarkFL
MHB
Here is the question:
Verify the following identity: 1 + cosx + cos2x = 1/2 + (sin5/2x) / (2sin1/2x)?
I have posted a link there to this thread so the OP can view my work.
Mathematics news on Phys.org
Hello Catlover0330,
We are given to verify:
$$1+\cos(x)+\cos(2x)=\frac{1}{2}+ \frac{\sin\left(\frac{5}{2}x \right)}{2 \sin\left(\frac{1}{2}x \right)}$$
Let's begin with the left side of the identity and rewrite it as follows:
$$1+\cos(x)+\cos(2x)=1+3+4\cos(x)+\cos(2x)-3-3\cos(x)$$
Using the identities:
$$8\cos^4(\theta)=3+4\cos(2\theta)+\cos(4\theta)$$
$$6\cos^2(\theta)=3+3\cos(2\theta)$$
We may write:
$$1+\cos(x)+\cos(2x)=1+8\cos^4\left(\frac{1}{2}x \right)-6\cos^2\left(\frac{1}{2}x \right)$$
Factor the right side:
$$1+\cos(x)+\cos(2x)=\left(4\cos^2\left(\frac{1}{2}x \right)-1 \right)\left(2\cos^2\left(\frac{1}{2}x \right)-1 \right)$$
Rewrite the first factor and use the double-angle identity for cosine on the second factor:
$$\cos(2\theta)=2\cos^2(\theta)-1$$
to obtain:
$$1+\cos(x)+\cos(2x)=\left(3-4\left(1-\cos^2\left(\frac{1}{2}x \right) \right) \right)\cos(x)$$
To the first factor on the right, apply the Pythagorean identity:
$$\sin^2(\theta)=1-\cos^2(\theta)$$
to obtain:
$$1+\cos(x)+\cos(2x)=\left(3-4\sin^2\left(\frac{1}{2}x \right) \right)\cos(x)$$
Multiply the right side by:
$$1=\frac{\sin\left(\frac{1}{2}x \right)}{\sin\left(\frac{1}{2}x \right)}$$
to obtain:
$$1+\cos(x)+\cos(2x)=\frac{\left(3\sin\left(\frac{1}{2}x \right)-4\sin^3\left(\frac{1}{2}x \right) \right)\cos(x)}{\sin\left(\frac{1}{2}x \right)}$$
To the first factor in the numerator on the right, apply the triple-angle identity for sine:
$$\sin(3\theta)=3\sin(\theta)-4\sin^3(\theta)$$
to obtain:
$$1+\cos(x)+\cos(2x)=\frac{\sin\left(\frac{3}{2}x \right)\cos(x)}{\sin\left(\frac{1}{2}x \right)}$$
To the numerator on the right, apply the product-to-sum identity:
$$\sin(\alpha)\cos(\beta)=\frac{\sin(\alpha-\beta)+\sin(\alpha+\beta)}{2}$$
to obtain:
$$1+\cos(x)+\cos(2x)=\frac{\sin\left(\frac{1}{2}x \right)+\sin\left(\frac{5}{2}x \right)}{2\sin\left(\frac{1}{2}x \right)}$$
Rewrite the right side using the algebraic property:
$$\frac{a+b}{c}=\frac{a}{c}+\frac{b}{c}$$
to obtain:
$$1+\cos(x)+\cos(2x)=\frac{\sin\left(\frac{1}{2}x \right)}{2\sin\left(\frac{1}{2}x \right)}+\frac{\sin\left(\frac{5}{2}x \right)}{2\sin\left(\frac{1}{2}x \right)}$$
Divide out common factor in numerator and denominator of first term on the right:
$$1+\cos(x)+\cos(2x)=\frac{1}{2}+\frac{\sin\left( \frac{5}{2}x \right)}{2\sin\left(\frac{1}{2}x \right)}$$
Shown as desired.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
