Verifying a macroscopic Maxwell equation
In summary, the electrostatic potential ##\phi(\vec{x}) = \phi_\text{free} (\vec{x}) + \phi_\text{ind} (\vec{x}) = \frac{1}{4 \pi \epsilon_0} \bigg( \int d^3 x'\ \frac{\rho_\text{free} (\vec{x}')}{|\vec{x} - \vec{x}'|} + \int d^3x'\ \frac{\vec{P} (\vec{x}') \cdot (\vec{x} - \vec{x}')}{|\vec{x} - \vec{x}'|^3} \bigg)## satisfies the macroscopic Maxwell equation ##\vec{\nabla
JulienB
408
Hi everybody! I have trouble understanding the following problem, hopefully somebody can help!
Show that the electrostatic potential
solves the macroscopic Maxwell equation ##\vec{\nabla} \cdot \vec{D} = \vec{\nabla} \cdot (\epsilon_0 \vec{E} + \vec{P}) = \rho_\text{free}##.
##\vec{E} = - \vec{\nabla} \phi##
##\Delta_x \bigg(\frac{1}{|\vec{x} - \vec{x}'|} \bigg) = -4 \pi \delta^{(3)} (\vec{x} - \vec{x}')##
##\frac{\vec{x} - \vec{x}'}{|\vec{x} - \vec{x}'|^3} = \vec{\nabla} \bigg(\frac{1}{|\vec{x} - \vec{x}'|} \bigg)##
I have seen the solution already, but there is one step I don't understand. Here is the beginning of the proof:
##\vec{\nabla} \cdot \vec{D} = - \epsilon_0 \Delta \phi + \vec{\nabla} \cdot \vec{P}##
which means I am expecting to find ##\Delta \phi = -\frac{1}{\epsilon_0} \rho_\text{free} (\vec{x}) + \frac{1}{\epsilon_0} \vec{\nabla} \cdot \vec{P}##. First I apply the Laplace-operator on ##\phi_\text{free}##:
##\Delta \phi_\text{free} (\vec{x}) = \frac{1}{4 \pi \epsilon_0} \int d^3x'\ \rho_\text{free} (\vec{x}') \Delta_x \bigg(\frac{1}{|\vec{x} - \vec{x}'|} \bigg)##
##= \frac{1}{4 \pi \epsilon_0} \int d^3x'\ \rho_\text{free} (\vec{x}') (-4 \pi \delta^{(3)} (\vec{x} - \vec{x}'))##
##= -\frac{1}{\epsilon_0} \rho_\text{free} (\vec{x})##
Here I have used the property of the Dirac delta function in the integral, and I got my first term pretty easily. The second term is actually precisely what is bothering me:
##\Delta \phi_\text{ind} (\vec{x}) = \frac{1}{4 \pi \epsilon_0} \int d^3x'\ \vec{P} (\vec{x}') \cdot \Delta_x \bigg( \frac{(\vec{x} - \vec{x}')}{|\vec{x} - \vec{x}'|^3} \bigg)##
##= \frac{1}{4 \pi \epsilon_0} \int d^3x'\ \vec{P} (\vec{x}') \cdot \Delta_x \bigg( \vec{\nabla}_x \frac{1}{|\vec{x} - \vec{x}'|} \bigg)##
##= \frac{1}{4 \pi \epsilon_0} \int d^3x'\ \vec{P} (\vec{x}') \cdot \vec{\nabla}_x \bigg( \Delta_x \frac{1}{|\vec{x} - \vec{x}'|} \bigg)##
##= \frac{-1}{\epsilon_0} \int d^3x'\ \vec{P} (\vec{x}') \cdot \vec{\nabla}_x \delta^{(3)} (\vec{x} - \vec{x}')##
Now I am not very happy with this expression. I guess I could put ##\vec{\nabla}_x## in front of ##\vec{P}## since it doesn't apply on ##x'##, but then I would get the wrong sign. And if I were to apply the Dirac delta function's property first, the result would be different and senseless. I think that this is anyway not the right way to proceed. In the solution, my teacher just indicates that he has used integration by parts but I do not really understand how! Here is what he wrote:
##\phi_\text{ind} (\vec{x}) = \frac{1}{4 \pi \epsilon_0} \int d^3x'\ \vec{P} (\vec{x}') \cdot \vec{\nabla}_x \bigg(\frac{1}{|\vec{x} - \vec{x}'|} \bigg)##
##\underbrace{=}_{P.I.} - \frac{1}{4 \pi \epsilon_0} \int d^3x'\ \vec{\nabla} \cdot \vec{P} (\vec{x}') \frac{1}{|\vec{x} - \vec{x}'|}##
(P.I. refers to integration by parts in German)
I assume that he performed the integration by parts by defining ##u=\vec{P} (\vec{x}')## and ##v' = \vec{\nabla}_{x'} \bigg(\frac{1}{|\vec{x} - \vec{x}'|} \bigg)## (since ##\vec{\nabla}_{x} \bigg(\frac{1}{|\vec{x} - \vec{x}'|} \bigg) = \vec{\nabla}_{x'} \bigg(\frac{1}{|\vec{x} - \vec{x}'|} \bigg)## I believe), but then I get:
##\phi_\text{ind} (\vec{x}) = \frac{1}{4 \pi \epsilon_0} \vec{P} (\vec{x}) \frac{1}{|\vec{x} - \vec{x}'|} - \frac{1}{4 \pi \epsilon_0} \int d^3x'\ \vec{\nabla}_{x'} \cdot \vec{P} (\vec{x}') \frac{1}{|\vec{x} - \vec{x}'|}##
which looks pretty close apart from the fact that his first term is gone. How is that? Is the polarization disappearing at the boundaries? Or do we assume that the boundaries are ##\pm \infty##, in which case it is the term that ##\frac{1}{|\vec{x} - \vec{x}'|}## is equal to 0. I feel like it is important that I do not misunderstand this step.Thank you very much in advance for your answers, I'm looking forward to reading you!Julien.
This is not introductory physics, for sure.
@qnach Really? Last time I posted about non relativistic electrodynamics in the advanced physics forum, it got moved here :DD
Yes
You are RIGHT
People in this forum is sick.
I simply mimic their tone.
@qnach but more seriously, can I move it to the other forum then? I don't see a button for doing so.
You can use the "Report" in the lower left of any post in the thread, and ask a Mentor to place this thread in the appropriate forum, if Introductory Physics is not the correct place. (I'll do that.)
Likes JulienB
@sammy Thanks a lot for the info and for moving the thread of course. Hopefully somebody will have an answer now :)
Problem solved, integration by parts was just never used. The solution is simply that:
##\vec{\nabla}_{x} \bigg(\frac{1}{|\vec{x} - \vec{x}'|} \bigg) = \begin{bmatrix} \partial_x \\ \partial_y \\ \partial_z \end{bmatrix} \frac{1}{\sqrt{(x-x')^2 + (y-y')^2 + (z-z')^2}}##
##= \frac{(\vec{x} - \vec{x}')}{|\vec{x} - \vec{x}'|^3} = - \vec{\nabla}_{x'} \left(\frac{1}{|\vec{x} - \vec{x}'|} \right)##
since
##\vec{\nabla}_{x'} \bigg(\frac{1}{|\vec{x} - \vec{x}'|} \bigg) = \begin{bmatrix} \partial_{x'} \\ \partial_{y'} \\ \partial_{z'} \end{bmatrix} \frac{1}{\sqrt{(x-x')^2 + (y-y')^2 + (z-z')^2}}##
##=\frac{(\vec{x}' - \vec{x})}{|\vec{x} - \vec{x}'|^3} ##.
I hope this is useful to anyone having their teacher believe that this comes from integration by parts. XDJulien.
This looks OK except it appears to me that the ##\vec{\nabla}_x## operator in the first integral should be with respect to the primed variables; that is, ##\vec{\nabla}_{x'}##.
Yes
OK, except for a sign error. ##\vec{\nabla}_{x} \bigg(\frac{1}{|\vec{x} - \vec{x}'|} \bigg) = -\vec{\nabla}_{x'} \bigg(\frac{1}{|\vec{x} - \vec{x}'|} \bigg)##
but then I get:
Yes, that all looks good. You can assume the integration over ##d^3x'## is over all of space. So, the boundary term is at infinity.
##= \frac{(\vec{x} - \vec{x}')}{|\vec{x} - \vec{x}'|^3} ##
Is the overall sign of the last expression correct?
Similarly, is the sign of the last expression correct?
Don't you need to do integration by parts in order to get the ##\vec{\nabla}_{x'}## operator to act on ##\vec{P}##?
Related to Verifying a macroscopic Maxwell equation
1. What is a macroscopic Maxwell equation?
A macroscopic Maxwell equation is a mathematical equation that describes the relationship between electric and magnetic fields in a macroscopic scale, taking into account the effects of materials and their properties.
2. Why is it important to verify a macroscopic Maxwell equation?
Verifying a macroscopic Maxwell equation is important because it ensures that the equation accurately describes the behavior of electric and magnetic fields in a macroscopic scale. It also allows us to make predictions and understand the behavior of electromagnetic phenomena in various materials.
3. How is a macroscopic Maxwell equation verified?
A macroscopic Maxwell equation can be verified through experimental observations and comparisons with theoretical predictions. This involves conducting experiments and collecting data to confirm that the equation accurately describes the behavior of electric and magnetic fields in the given material.
4. What are some factors that can affect the verification of a macroscopic Maxwell equation?
Some factors that can affect the verification of a macroscopic Maxwell equation include the accuracy and precision of experimental measurements, the complexity of the material being studied, and potential sources of error in the experimental setup.
5. Are there any limitations to a macroscopic Maxwell equation?
Yes, there are limitations to a macroscopic Maxwell equation. It is based on certain assumptions and simplifications, such as the materials being homogenous and isotropic, and may not accurately describe the behavior of electric and magnetic fields in all materials or under extreme conditions.
