Verifying an Inequality Involving the Complex Exponential Function
In summary: The modulus of z^2 is then ##|z^2| = |x^2-y^2|##, and so ##|e^{z^2}| = e^{|x^2-y^2|}##. Since ##e^{|z|^2} = e^{x^2+y^2}##, it is clear that ##e^{|z|^2} \ge |e^{z^2}|##. In summary, by using the theorem that states Re(z) ≤ |z| and manipulating the expressions, it can be shown that ##|e^{z^2}| \le e^{|z|^2}## for all z, or in other words, the absolute
Bashyboy
1,421
Demonstrate that ##|e^{z^2}| \le e^{|z|^2}##
We have at our disposal the theorem which states ##Re(z) \le |z|##. Here is my work:
##e^{|z|^2} \ge e^{(Re(z))^2} \iff## By the theorem stated above.
##e^{|z|^2} \ge e^x##
We note that ##y^2 \ge 0##, and that multiplying by ##-1## will give us ##- y^2 \le 0##; adding ##x^2## to both sides gives us ##x^2 - y^2 \le x^2##. Substituting this in gives us
##e^{|z|^2} \ge e^{x^2 - y^2}##. I calculated ##|e^{z^2}|## and found that it was ##e^{x^2-y^2}##. Therefore,
________________________________________________________________________
Here is the one issue I see with the proof, but I may have resolved this issue: was the first step justly done? I believe so, and here is why:
##e^{f(z)} \ge e^{g(z)} \iff##
##\ln e^{f(z)} \ge \ln e^{g(z)} \iff##
##f(z) \ge g(z)##.
So, one exponential function is greater than the other when its argument function is greater than the other for all ##z##.
Does this seem correct?
That seems reasonable. Just remember that you can only compare real numbers, so if f(z) and g(z) are purely real, you are allowed to use the inequalities.
You could also get to the result directly by defining ##z=x+iy##, then ##|z| = \sqrt{x^2+y^2}## and ##z^2 = x^2 -2ixy - y^2##.
Related to Verifying an Inequality Involving the Complex Exponential Function
1. What is the complex exponential function?
The complex exponential function is a mathematical function of the form f(z) = e^z, where z is a complex number. It is an extension of the real exponential function, e^x, and is defined as the infinite sum of powers of the complex number z.
2. How do you verify an inequality involving the complex exponential function?
To verify an inequality involving the complex exponential function, you can use algebraic manipulation, properties of inequalities, and the rules of complex numbers. You can also use graphical methods, such as plotting the complex exponential function on the complex plane, to visually understand the inequality.
3. Can you explain the properties of the complex exponential function?
The complex exponential function has many properties, including the following: it is an entire function, meaning it is analytic everywhere in the complex plane; it has a period of 2πi, meaning that it repeats every 2πi units on the complex plane; and it has a unique inverse function, the complex logarithm.
4. What are some common applications of the complex exponential function?
The complex exponential function has various applications in mathematics and physics. In mathematics, it is used to solve differential equations and to study the behavior of complex numbers. In physics, it is used to describe wave phenomena, such as electromagnetic waves, sound waves, and quantum mechanical systems.
5. How can one use the complex exponential function to solve inequalities?
To solve an inequality involving the complex exponential function, you can use properties of inequalities, such as multiplying or dividing both sides by a positive real number, or adding or subtracting the same value from both sides. You can also use the properties of the complex exponential function, such as its monotonicity and periodicity, to simplify the inequality and find its solutions.
