I Verifying properties of Green's function
psie
TL;DR Summary
I want to verify properties of the Green's function and its derivatives, such as continuity, discontinuity and being a solution to a linear homogeneous ODE.
I'm reading about fundamental solutions to differential operators in Ordinary Differential Equations by Andersson and Böiers. There is a remark that succeeds a theorem that I struggle with verifying. First, the theorem:
Theorem 6. Let $$L(t,\lambda)=\lambda^n+a_{n-1}(t)\lambda^{n-1}+\ldots+a_1(t)\lambda+a_0(t)\quad\text{and }D=\frac{d}{dt}.\tag1$$
Denote by ##E(t,\tau)## the uniquely determined solution ##u(t)## of the initial value problem
\begin{align}
&L(t,D)u=0 \tag2\\
&u(\tau)=u'(\tau)=\ldots=u^{(n-2)}(\tau)=0,\quad u^{(n-1)}(\tau)=1. \tag3
\end{align}
Then,
$$y(t)=\int_{t_0}^t E(t,\tau)g(\tau)d\tau\tag4$$
is the solution of the problem
\begin{align}
&L(t,D)y=g(t) \tag5\\
&y(t_0)=y'(t_0)=\ldots=y^{(n-1)}(t_0)=0. \tag6
\end{align}
If the leading coefficient in ##(1)## is not ##1## but ##a_n(t)##, then the last condition in ##(3)## reads ##u^{(n-1)}(\tau)=1/a_n(\tau)## and ##(4)## changes to $$y(t)=\int_{t_0}^t E(t,\tau)\frac{g(\tau)}{a_n(\tau)}d\tau.\tag7$$ Put ##\overline{E}(t,\tau)=\frac{E(t,\tau)}{a_n(\tau)}## and define $$F(t,\tau)=\begin{cases} \overline{E}(t,\tau) &\text{when } t\geq\tau \\ 0 &\text{when } t<\tau.\end{cases}\tag8$$ then ##F(t,\tau)## satisfies the following properties:
  1. ##\frac{d^kF}{dt^k}(t,\tau)## is a continuous function of ##(t,\tau)## when ##k=0,1,\ldots,n-2.##
  2. ##\frac{d^{n-1}F}{dt^{n-1}}(t,\tau)## is continuous when ##t\neq\tau##, and has a step discontinuity of height ##1/a_n(\tau)## across the line ##t=\tau##.
  3. ##L(t,D)F(t,\tau)=0,\quad t\neq \tau##.
The authors note that this is easily verified by noting that ##E(t,\tau)## solves the IVP ##(2)## and ##(3)##, yet I have hard time verifying this to myself.
First of all, I'm confused about them writing ##\frac{d^k}{dt^k}## instead of ##\frac{\partial^k}{\partial t^k}##. Is this because we view the function as a function of ##t## only? If so, then 1. makes very little sense to me. How can the ##k##th derivative (##0\le k\le n-2##) of ##F## with respect to ##t## be continuous?
Second, I do not see how either 2. or 3. follows from the fact ##E(t,\tau)## solves ##(1)## and ##(2)##. I'd be very grateful if someone could share their understanding on the matter.
\tau is regarded as a parameter of the IVP (2,3), so d/dt here means \partial/\partial t.
We know that both \bar{E} and 0 are n - 1 times differentiable with respect to t: 0 trivially, and \bar E because it is the solution of the IVP (2,3), so its first n - 1 derivatives with respect to t exist and are continuous in t. Continuity of \bar E and its t-derivatives in (t,\tau) jointly follows from the fact that if you write \bar E(t,\tau) = A_1(\tau)u_1(t) + \dots + A_n(\tau)u_n(t) for n linearly independent solutions u_k of (2), then the A_k can be shown to be continuous in \tau.
F is defined as either \bar E or zero so F and its first n - 1 derivatives with respect to t can fail to be continuous in (t,\tau) only at the boundary of the regions where those definitions are applied, ie. when t = \tau. By construction <br /> \frac{\partial^k F}{\partial t^k}(\tau,\tau) = \begin{cases} 0 &amp; k = 0, \dots, n-2 \\<br /> 1/a_n(\tau) &amp; k = n - 1. \end{cases} but <br /> \lim_{t \to \tau^{-}} \frac{\partial^k F}{\partial t^k}(t,\tau) = 0.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
