Verifying solution to first order differential equation
In summary, the given function y=x+4\sqrt{x+2} is an explicit solution of the given equation (y-x)y'=y-x+8 where y=x+4\sqrt{x+2}. This is shown by verifying that the function satisfies the differential equation and providing at least one interval of definition. Additionally, the function can be explicitly solved using a brute force method, resulting in the same solution.
find_the_fun
148
Verify the indicated function y=phi(x) is an explicit solution of the given equation. Consider the phi function as a solution of the differential equation and give at lease one interval I of definition.
\(\displaystyle (y-x)y'=y-x+8\) where \(\displaystyle y=x+4\sqrt{x+2}\)
So the derivative is \(\displaystyle y'=1+\frac{2}{\sqrt{x+2}}\)
and the LHS becomes \(\displaystyle (y-x)(1+\frac{2}{\sqrt{x+2}})=
y+\frac{2y}{\sqrt{x+2}}-x-\frac{2x}{\sqrt{x+2}}=\)
\(\displaystyle x+4\sqrt{x+2}+2(x+\frac{4 \sqrt{x+2}}{\sqrt{x+2}})-x-\frac{2}{\sqrt{x+2}}=4\sqrt{x+2}+2x+8-\frac{2x}{\sqrt{x+2}}\)
and the RHS becomes \(\displaystyle y-x+8-x+4\sqrt{x+2}-x+8=4\sqrt{x+2}+8\)
which isn't equal but the answer key seems to think it is because it gives an interval of definition.
I agree that if:
then:
Now, let's look at the left side of the ODE:
\(\displaystyle (y-x)y'=\left(x+4\sqrt{x+2}-x \right)\left(1+\frac{2}{\sqrt{x+2}} \right)=4\sqrt{x+2}+8\)
And next, let's look at the right side:
\(\displaystyle y-x+8=x+4\sqrt{x+2}-x+8=4\sqrt{x+2}+8\)
This then shows that:
[tex]\displaystyle \begin{align*} \left( y - x \right) \, \frac{dy}{dx} &= y - x + 8 \end{align*}[/tex]
If [tex]\displaystyle \begin{align*} y = x + 4\sqrt{x+2} \end{align*}[/tex] then [tex]\displaystyle \begin{align*} \frac{dy}{dx} = 1 + \frac{2}{\sqrt{x + 2}} \end{align*}[/tex] and so substituting into the DE we have:
[tex]\displaystyle \begin{align*} LHS &= \left( y - x \right) \, \frac{dy}{dx} \\ &= \left( x + 4\sqrt{x + 2} - x \right) \left( 1 + \frac{2}{\sqrt{x + 2}} \right) \\ &= x + \frac{2x}{\sqrt{x + 2}} + 4\sqrt{x + 2} + 8 - x - \frac{2x}{\sqrt{x + 2}} \\ &= \left( x + 4\sqrt{x + 2} \right) - x + 8 \\ &= y - x + 8 \\ &= RHS \end{align*}[/tex]
Another possibility is brute force, actually solving the DE:
[tex]\displaystyle \begin{align*} \left( y - x \right) \, \frac{dy}{dx} &= y - x + 8 \\ \frac{dy}{dx} &= \frac{y - x + 8}{y - x} \end{align*}[/tex]
Make the substitution [tex]\displaystyle \begin{align*} u = y - x \implies \frac{du}{dx} = \frac{dy}{dx} - 1 \implies \frac{dy}{dx} = \frac{du}{dx} + 1 \end{align*}[/tex] and the DE becomes
[tex]\displaystyle \begin{align*} \frac{dy}{dx} &= \frac{y - x + 8}{y - x} \\ \frac{du}{dx} + 1 &= \frac{u + 8}{u} \\ \frac{du}{dx} &= \frac{u + 8}{u} - 1 \\ \frac{du}{dx} &= \frac{8}{u} \\ u\,\frac{du}{dx} &= 8 \\ \int{ u\,\frac{du}{dx}\,dx} &= \int{8\,dx} \\ \int{u\,du} &= 8x + C_1 \\ \frac{1}{2}u^2 + C_2 &= 8x + C_1 \\ \frac{1}{2}u^2 &= 8x + C_1 - C_2 \\ u^2 &= 16x + C \textrm{ where } C = 2C_1 - 2C_2 \\ \left( y - x \right) ^2 &= 16x + C \\ y - x &= \sqrt{16x + C} \\ y &= x + \sqrt{16x + C} \end{align*}[/tex]
Of course, your given function [tex]\displaystyle \begin{align*} y = x + 4\sqrt{x + 2} \end{align*}[/tex] is the case where [tex]\displaystyle \begin{align*} C = 32 \end{align*}[/tex], thus your given function is a solution to the DE.
In order to verify that y=phi(x) is an explicit solution of the given differential equation, we need to substitute y=phi(x) into the equation and see if it satisfies the equation for all values of x in a certain interval.
In this case, we can take the interval I = [0, ∞) as the interval of definition for the function phi(x) = x+4√(x+2). This means that for all values of x greater than or equal to 0, the function phi(x) is defined and thus can be used as a solution to the differential equation.
Substituting y=phi(x) into the given equation, we get:
(phi(x)-x)(phi'(x)) = phi(x)-x+8
(x+4√(x+2)-x)(1+2/(√(x+2))) = x+4√(x+2)-x+8
4√(x+2)+8 = 4√(x+2)+8
As we can see, the equation is satisfied for all values of x in the interval I = [0, ∞). Therefore, we can conclude that phi(x) = x+4√(x+2) is an explicit solution of the given differential equation.
In general, to verify a solution to a differential equation, we need to substitute the solution into the equation and check if it satisfies the equation for all values in the interval of definition. If it does, then we can say that the solution is valid and can be used to solve the differential equation.
FAQ: Verifying solution to first order differential equation
What is the process for verifying a solution to a first order differential equation?
The process for verifying a solution to a first order differential equation involves substituting the proposed solution into the equation and simplifying to see if it satisfies the equation.
How do you know if a proposed solution is a valid solution to a first order differential equation?
A proposed solution is considered a valid solution to a first order differential equation if it satisfies the equation for all values of the independent variable and initial conditions.
Can a first order differential equation have more than one solution?
Yes, a first order differential equation can have an infinite number of solutions. However, only one solution will satisfy the initial conditions.
What is the importance of verifying a solution to a first order differential equation?
Verifying a solution to a first order differential equation is important because it ensures that the solution is accurate and valid. It also allows for the identification of any errors or mistakes in the solution.
Are there any common mistakes to avoid when verifying a solution to a first order differential equation?
Some common mistakes to avoid when verifying a solution to a first order differential equation include incorrect substitutions, algebraic errors, and not considering the initial conditions in the verification process.
