Verifying that a critical damped oscillator approaches zero the fastest.
In summary, the conversation discusses the general form of the equation for damped oscillations and the solution in the critically damped case. It also explores the behavior of the oscillation in the underdamped and overdamped cases, with a focus on the exponents in the expressions. It is shown that when b<k, the oscillation will reach zero faster in the critically damped case than in the underdamped case. In the overdamped case, it is asked how to show that the exponents are still less than omega, and it is proven mathematically that this is indeed the case.
Quantumpencil
96
Not actually a homework problem, just something from my book I'm trying to verify.
The general form of the equation for damped oscillations...
[tex]\ x(t) = e^{-\gamma t}(Ae^{\sqrt{\gamma^{2}-\omega^{2}}t}+Be^{-\sqrt{\gamma^{2}-\omega^{2}}t})[/tex]
Here gamma = b/m, where b is the constant associated with the strength of a velocity dependent damping force. (A and B are constants determined by the initial conditions)
and omega is the angular frequency, root (k/m).
And, in the critically damped case, the solution is
[tex]\ x(t) = e^{-\gamma t}(A+Bt)[/tex]
It's obvious that it b<k, that is gamma<omega, then when the oscillation is critically damped (gamma = omega), it will reach zero more quickly. When the oscillation is underdamped, then the exponents in the larger expression in parenthesis are imaginary, so we have simple harmonic motion falling off as e^-gamma(t), and since gamma is less than omega, this expression reaches zero faster than in the critically damped case, which falls off as e^-omega(t).
However when the oscillation is overdamped, and we have b>k, gamma>omega, how can we show that the exponents (which are then positive) are still less than omega? That is, how can we show
[tex]\gamma-\sqrt{\gamma^{2}-\omega^{2}}\leq\omega[/tex]
Rearranging the inequality etc.:
[tex]\gamma -\omega \leq \sqrt{\gamma^2-\omega^2} [/tex]
But we know that: [tex]\gamma-\omega = \sqrt{\gamma-\omega}\sqrt{\gamma-\omega}[/tex].
So we have:
[tex]\sqrt{\gamma-\omega}\sqrt{\gamma-\omega} \leq \sqrt{\gamma-\omega}\sqrt{\gamma+\omega} [/tex]
Wich is obviously true, since [tex]\gamma > \omega[/tex]
One way to show that the exponents are still less than omega in the overdamped case is to use the quadratic formula to solve for the roots of the expression under the square root. This will give you two possible values for the exponents, one positive and one negative. Since gamma is greater than omega, the positive exponent will be smaller in magnitude than omega, and thus the overdamped case will still approach zero faster than the critically damped case.
FAQ: Verifying that a critical damped oscillator approaches zero the fastest.
1. How does a critical damped oscillator behave?
A critical damped oscillator is a type of mechanical oscillator that reaches its equilibrium position in the fastest possible time without any oscillations or overshooting. It is considered the most efficient type of oscillator for reaching equilibrium.
2. What is the significance of verifying that a critical damped oscillator approaches zero the fastest?
Verifying the behavior of a critical damped oscillator is important for ensuring the accuracy and efficiency of mechanical systems that rely on these types of oscillators. It also helps in understanding the underlying principles of damping and oscillation in physics.
3. How is the speed of a critical damped oscillator determined?
The speed at which a critical damped oscillator approaches zero is determined by its damping ratio, which is a measure of how quickly the oscillations decrease. A higher damping ratio results in a faster approach to equilibrium.
4. What factors can affect the behavior of a critical damped oscillator?
The behavior of a critical damped oscillator can be affected by factors such as the mass of the object, the stiffness of the spring, and the amount of damping present. These factors can be adjusted to achieve the desired speed of approach to equilibrium.
5. How is the behavior of a critical damped oscillator verified?
The behavior of a critical damped oscillator can be verified through mathematical analysis and experimental testing. By measuring the response of the oscillator to different damping ratios and external forces, its behavior can be accurately determined and verified.
