Verifying that a matrix T represents a projection operation
In summary: In this case, the source of light is tilted at an angle whose tangent is ##c##.This is true in general. If ##V## and ##W## are two subspaces with an angle between them, and ##P## is a projection onto ##W##, then the kernel of ##P## consists of all vectors orthogonal to ##W##, and the image of ##P## is the orthogonal projection of ##V## onto ##W##. So the kernel of ##P## is the orthogonal complement of the image of ##P##.In this case, if we let ##n## be a unit vector normal to ##W## and ##x## be arbitrary, then ##\langle n, Px\rangle = 0
Seydlitz
263
Hello guys,
I want to verify or rather show that a given matrix ##T## does represent a projection from ##\mathbb{R^{3}}## to a particular plane, also lying in ##\mathbb{R^{3}}##. Would it be enough to pre-multiply that matrix to an arbitrary vector ##(x,y,z)##, and see if the resulting vector is orthogonal to the normal vector of that given plane, thus implying that the vector is projected successfully to the plane?
Or do I need to row reduce the matrix ##T## until I can see the basis vectors used in the original ##T##, and verify that they all lie on the plane? Or rather since I can also get the basis of the kernel, will showing that the basis of the kernel is parallel with the normal of the plane enough? Geometrically I imagine that the kernel space is all of the vectors that are orthogonal to the plane and their projection to that plane will be 0.
Thanks
Seydlitz said:
Hello guys,
This is necessary but not sufficient. If ##n## is normal to the plane and ##\langle n, Tx\rangle = 0## for all ##x##, then the image of ##T## is contained in the plane, but that doesn't necessarily mean that ##T## is a projection onto the plane. For example, consider the matrix
$$T = \begin{pmatrix}0 & 0 & 0 \\ 0 & 0 & 0 \\ 0 & 0 & 1 \end{pmatrix}$$
This matrix has the property that ##\langle n, Tx\rangle = 0##, where ##n = \begin{pmatrix}1 \\ 0 \\ 0 \end{pmatrix}## and ##x## is any vector. So the image lies in the plane whose normal vector is ##\begin{pmatrix}1 \\ 0 \\ 0\end{pmatrix}##. But it is not a projection onto that plane because the image only has dimension 1.
For another example, consider the matrix
$$T = \begin{pmatrix}0 & 0 & 0 \\ 0 & 2 & 0 \\ 0 & 0 & 2 \end{pmatrix}$$
Once again, we have ##\langle n, Tx\rangle = 0##, where ##n = \begin{pmatrix}1 \\ 0 \\ 0 \end{pmatrix}## and ##x## is any vector. The dimension of the image is correct (2), but this is still not a projection because it stretches vectors lying in the plane, e.g. it maps ##\begin{pmatrix}0 \\ 1 \\ 0\end{pmatrix}## to ##\begin{pmatrix}0 \\ 2 \\ 0\end{pmatrix}##. So you also need a constraint ensuring that no such stretching (and also no rotating) occurs. This is neatly captured by the condition ##T^2 = T##. Indeed, a matrix represents a projection if and only if it satisfies ##T^2 = T##.
So to summarize, if you want to show that a 3x3 matrix is a projection onto a particular plane, you need to verify all of the following:
  1. ##T^2 = T##, so ##T## is a projection
  2. ##\dim(\ker(T)) = 1## or equivalently, ##\dim(\text{im}(T)) = 2##, so ##T## projects onto a plane
  3. ##\langle n, Tx\rangle = 0## where ##n## is normal to the plane and ##x## is arbitrary, so ##T## projects onto the specified plane
You can find equivalent conditions which will allow you to do less work. [strike]For example, you can replace condition 3 with ##Tn = 0##.[/strike] [correction: If condition 3 is replaced with ##Tn=0## then not only is ##T## a projection, it is in fact an orthogonal projection.] But the basic idea remains the same.
Thanks for the comprehensive information jbunniii, I really appreciate it.
By the way I just realized the fact that the kernel space of a projection matrix is orthogonal to the image of the the projection. Is this true in general? For example if I have a subspace ##W## and a linear transformation from a vector space ##V## to ##W##. Can we consider the kernel of that transformation as the orthogonal complement of ##W##?
Actually, that's only true of orthogonal projections. For general projections, it need not be true. Consider for example
$$T = \begin{pmatrix}0 & 0 \\ c & 1 \\ \end{pmatrix}$$
This is a projection matrix, because ##T^2 = T##. The image is the subspace consisting of all scalar multiples of ##\begin{pmatrix}0 \\ 1 \end{pmatrix}##. The kernel is the subspace consisting of all ##\begin{pmatrix}x \\ y \end{pmatrix}## satisfying ##cx + y = 0##, or in other words, all scalar multiples of ##\begin{pmatrix}1 \\ -c \end{pmatrix}##.
You can think of ##T## as a source of light aimed in the direction of ##\begin{pmatrix}1 \\ -c \end{pmatrix}##, which projects a given vector onto its "shadow" on the image subspace. If the source of light is directly overhead (##c = 0##) then it's an orthogonal projection, otherwise it's called an oblique projection.
for your question! To verify that a matrix T represents a projection operation, you can use a combination of the methods you mentioned. Pre-multiplying the matrix to an arbitrary vector and checking if the resulting vector is orthogonal to the normal vector of the plane is a good first step. This will show that the projection is successful in projecting the vector onto the plane.
To further verify, you can also row reduce the matrix T and check if the basis vectors used in the original T lie on the plane. If they do, this would provide additional evidence that T represents a projection onto that plane.
Additionally, you can check the basis of the kernel and see if it is parallel to the normal vector of the plane. As you mentioned, the kernel space represents all the vectors that are orthogonal to the plane, so if the basis of the kernel is parallel to the plane's normal vector, this would further support the fact that T represents a projection operation onto that plane.
Overall, using a combination of these methods will provide a more comprehensive verification that T represents a projection operation onto a specific plane in ##\mathbb{R^{3}}##.
Related to Verifying that a matrix T represents a projection operation
1. What is a projection operation?
A projection operation is a mathematical operation that maps a vector onto a subspace, giving the component of the vector that lies in that subspace. It is commonly used in linear algebra to simplify problems and find solutions.
2. How do you verify that a matrix T represents a projection operation?
To verify that a matrix T represents a projection operation, you can check if T is idempotent (T^2 = T), symmetric (T = T^T), and has eigenvalues of either 0 or 1. These properties ensure that T will map any vector onto itself or its projection onto a subspace.
3. What are the applications of projection operations in science?
Projection operations have a wide range of applications in science, including image processing, signal processing, and data compression. They are also commonly used in physics, engineering, and computer science to simplify calculations and find solutions to complex problems.
4. Can a matrix T represent multiple projection operations?
Yes, a matrix T can represent multiple projection operations if it satisfies the properties of idempotency, symmetry, and having eigenvalues of 0 or 1. This means that T can project onto multiple subspaces at the same time.
5. Are there any limitations to using projection operations?
One limitation of using projection operations is that they can only be applied to linearly independent subspaces. Additionally, projection operations may not always accurately represent the original data, as they can introduce errors and distortions. It is important to carefully consider the application and choose the appropriate projection operation for the problem at hand.
  • Linear and Abstract Algebra
