[verilog]confuse on CPU's system bus
In summary: The use of ".bus" is necessary because it allows for a more efficient and organized way of connecting signals in a system. In summary, the ".bus" is used to define an interface port and to connect multiple signals at once in a more efficient manner.
hoheiho
47
I am trying to understand a simply CPU which written in system verilog. I understand most of them a part from the red colour part.
Code:
import cpu_defs::*;
module IR [COLOR="Red"](CPU_bus.IR_port bus)[/COLOR];
logic [WORD_W-1:0] instr_reg;
assign [COLOR="red"]bus.[/COLOR]sysbus = [COLOR="red"]bus.[/COLOR]Addr_bus ? {{OP_W{1'b0}},instr_reg[WORD_W-OP_W-1:0]} : 'z ;
always_comb
  [COLOR="red"]bus.[/COLOR]op = instr_reg[WORD_W-1:WORD_W-OP_W];
always_ff @ (posedge [COLOR="red"]bus.[/COLOR]clock, negedge [COLOR="red"]bus.[/COLOR]n_reset)
  begin
  if (![COLOR="red"]bus.[/COLOR]n_reset)
    instr_reg <= 0;
  else
    if ([COLOR="red"]bus.[/COLOR]load_IR)
      instr_reg <= [COLOR="red"]bus.[/COLOR]sysbus;
  end
endmodule
Normally I will just write it like that, without .bus:
Code:
module IR (input clock, n_reset, Addr_bus, load_IR,
                inout sysbus,
                output op);
Why it need .bus in here? Because it has connection with the system bus? In the interface part, it doesn't use any .bus :
Code:
modport IR_port(input clock, n_reset, Addr_bus, load_IR,
                inout sysbus,
                output op);
Thanks for the help
Ivan
Homework EquationsN/AThe Attempt at a SolutionThe use of ".bus" in this module is to define an interface port for the module. The port is then used to connect the module to other modules. The ".bus" allows multiple signals to be connected all at once. For example, in the code above, the "sysbus" and the "op" are both connected to the CPU_bus.IR_port bus. This allows multiple signals to be connected and accessed by other modules.
Related to [verilog]confuse on CPU's system bus
1. What is a system bus in a CPU?
A system bus is a communication pathway that connects the different components of a CPU, such as the memory, input/output devices, and the central processing unit, allowing them to exchange data and instructions.
2. How does a system bus work in a CPU?
The system bus works by using a set of electronic signals to transfer data and instructions between the various components of a CPU. It operates on a clock cycle, where data is transferred from one component to another during each cycle.
3. What is the purpose of a system bus in a CPU?
The main purpose of a system bus is to facilitate the transfer of data and instructions between the different components of a CPU. It helps to improve the efficiency and speed of the CPU by providing a dedicated communication pathway.
4. What are the different types of system buses in a CPU?
There are typically three types of system buses in a CPU: the data bus, the address bus, and the control bus. The data bus is responsible for transferring data between the CPU and memory, the address bus is used to specify the location of data in the memory, and the control bus controls the flow of data and instructions within the CPU.
5. How does the system bus affect the overall performance of a CPU?
The system bus plays a crucial role in determining the overall performance of a CPU. A wider and faster system bus can transfer more data and instructions at once, resulting in improved processing speed. Therefore, a well-designed system bus is essential for the efficient functioning of a CPU.
10K
19K
12K
9K
20K
