MHB Vertical and Horizontal Asymptotes
  • Thread starter Thread starter mathewslauren
    Horizontal Vertical
In the inverse variation equation y = (1 / (x - 3)) - 6, the vertical asymptote occurs where the denominator equals zero, which is at x = 3. The horizontal asymptote is determined by the behavior of the function as x approaches infinity, leading to y = -6. As x increases, the value of y approaches -6, indicating that the function levels off at this line. Understanding asymptotes involves analyzing how the function behaves as the denominator changes. This foundational knowledge is essential for graphing and interpreting the function accurately.
mathewslauren
In an inverse variation equation, what are the asymptotes and how do you find them? For example,
I was given the equation: y= [1 \ (x - 3)] - 6 and asked to find the vertical and horizontal asymptote.
I don't really understand what they are and why y= -6 and x=3. Thanks for any help!
Mathematics news on Phys.org
Hello and welcome to MHB, mathewslauren! (Wave)
We are given:
$$y=\frac{1}{x-3}-6$$
Now, before we discuss asymptotes, think about if you have a fraction, and you hold the numerator constant, and let the denominator vary. What happens to the value of the fraction if the denominator get larger and larger, without bound...where is the value of the fraction itself headed...and likewise, what if we let the denominator get closer and closer to zero...what happens to the value of the fraction then?
The fraction would get smaller as the denominator increases, and larger as it decreases.
Well, that's true, but can you be more specific?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
