Vertical Cable, Torque, Force applied to Wheels
In summary: It might be helpful to know the stiffness of the cable in order to design the climber around it.I think we will have to test it to see how it works!In summary, our team is working on a basic robotic climber that climbs a cable. They decided to use "offset" wheels on either side of the cable and adjust their height for proper grip. They found that the resistance force (how much harder the motor has to work) increased with the curvier the cable, and that increasing the tension on the cable will only cause a modest increase in bearing friction. They are still testing the Climber to see how it works.
breadvsrice
I am working on a project at my University. It's extra-curricular and not homework related. At the end we will give a report on what we learned during the development. Our team is working on some ideas for a basic robotic climber, that climbs a cable (similar to a seatbelt).
What we decided to try, was to "offset" the wheels on either side of the cable, and adjust their height for proper grip on the cable.
I was hoping someone would know how to calculate forces like as shown in the pic below?
The best I could find so far, was the capstan equation for calculating friction based on the force applied to the cable, and the number of times it is wrapped around the wheel. Ex: π/6 radians.
What I really want to know, is the "resistance force," or how much harder the motor has to work to turn the wheels based on how "curved" the belt is...
As you can see in the picture, the cable "bends" through the tires. So, when a pulling force is applied to the cable (balloon and anchor) it creates a force that wants to "straighten" the cable. When the cable tries to straighten itself, it applies a force to wheel 1 and 2.
Logic tells me that this force will increase friction, and make it harder for the wheels to rotate. (Also pushes the shaft against the walls of the bearings, etc. slight, but still added friction. I will ignore this for now, and focus only on the wheel-cable part)
1) Am I right in assuming the "curvier" the cable is, the higher the straightening force, and the harder for the motor to work?
2) How can I calculate how much harder the motor has to work? (Ex. No stress = 1Nm to start climbing. With stress = 2Nm needed to start climbing. How do I calculate this?)
Here are the pictures:
https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-frc1/t1/400596_10202953978913296_150499901_n.jpg
There is no frictional drag from the wheels at all if the belt is not slipping relative to the wheels - all the resistance comes from whatever torque is required to keep the wheel rotating about its axis (This is why we use belt drives in so many applications). You will, however, get friction in both guides if the moving belt is rubbing against them (which is why when we use belt drives, we prefer to use tensioner and idler pulleys to change the direction).
Increasing the tension will increase the load on the motor but only because it increases the load on the bearings. This should be a modest effect if the bearings are any good. You would need to measure how bearing friction varies with bearing load. I don't believe you can calculate it.
Thanks for the quick response! This was our original thought, that the rotation was independent of friction as it isn't slipping, but we noticed that when you held the cable loosely, the climber would go up and down easily. But, if you pulled on both ends of the cable with an decent bit of human-only force, you could keep the climber from sliding down do to gravity. It also made it harder for the climber to go up. Our bearings are ball bearings, 8mm diameter, 4mm center hole, 3mm thick. They are very smooth. Each one is about $3 per bearing, so of decent quality. We didn't think the "only" force making it harder to climb was just because of the extra stress on the shaft/bearing...But maybe that is what the problem was.
So, if we decrease the force at points F1 and F2 in the pic above, it should decrease stress on the bearings, reducing friction there...maybe this is all we need to do. Guess we will just have to test a little and see how it goes. So, "rolling friction" doesn't play apart here?
EDIT: Also, how would you go about calculating the F1 and F2 values anyway? By pulling both ends of the cable, you are definitely causing a force to be applied at those points. Is there an equation to use here?
What's the cable made of? If it's compressible but not very elastic then rolling resistance could be a factor.
Likes 1 person
The cable is made of something called "Technora" made by Teijin.
http://www.teijinaramid.com/aramids/technora/
It is moderately flexible, but also kind of stiff. Now that I think about it, the climber might not be able to climb because the cable itself can't "bend" fast enough to make that "S" shape with the wheels...if this is the case, maybe a more flexible cable would work better, or designing the climber so it doesn't need the cable to "bend" or "flex" as much?
Thanks for the insight! Interesting thoughts...
Related to Vertical Cable, Torque, Force applied to Wheels
1. What is a vertical cable?
A vertical cable is a type of cable or rope that is oriented vertically, meaning it hangs or is pulled in a straight line from top to bottom. This is in contrast to a horizontal cable, which runs parallel to the ground.
2. How is torque related to wheels?
Torque is a measure of rotational force. In the context of wheels, torque is the force that causes the wheel to rotate. This can come from various sources, such as an engine in a car or a motor in a bicycle.
3. What is the force applied to wheels?
The force applied to wheels refers to the amount of force that is exerted on a wheel to make it move or rotate. This force can come from various sources, such as an engine, a person pushing a bike, or gravity on a downhill slope.
4. How does a vertical cable affect the torque applied to a wheel?
A vertical cable can affect the torque applied to a wheel by changing the direction of the force being applied. For example, if a vertical cable is attached to a wheel and pulled downwards, it will create a torque that will cause the wheel to rotate. This is commonly seen in pulley systems.
5. Can a vertical cable be used to increase the force applied to a wheel?
Yes, a vertical cable can be used to increase the force applied to a wheel. This is because the tension in the cable can amplify the force being applied to the wheel. However, the amount of force that can be applied will depend on the strength and properties of the cable and the system it is being used in.
  • Mechanics
  • Mechanics
  • Mechanics
