Vertical Circles Centripetal Acceleration
In summary, the conversation discusses the problem of finding the minimum radius of a vertical loop for a jet pilot's aircraft so that the centripetal acceleration at the bottom of the loop does not exceed 6 Gs. The relevant equations for this problem are a = v^2 / r and F = ma, and the solution involves drawing a free body diagram and using the expression for centripetal acceleration.
Pedgepoke
A jet pilot takes his aircraft in a vertical loop. V is 840 km/hr (233.3 m/s) find the min. radius of the loop to that the centripetal acceleration at the bottom does not exceed 6 Gs.
a = v^2 / r
F = ma
I don't know where to start. Confused about the Sum part (Fx and Fy)
Start by drawing a free body diagram of the pilot at the bottom of the circle.
On edit: Actually you don't need the FBD. What is an expression for the centripetal acceleration? Hint: It's one of the relevant equations.
FAQ: Vertical Circles Centripetal Acceleration
1. What is a vertical circle?
A vertical circle is a circular path that is oriented in a vertical plane. This means that the circle is perpendicular to the ground or horizontal surface.
2. What is centripetal acceleration?
Centripetal acceleration is the acceleration that an object experiences when it moves in a circular path. It is always directed towards the center of the circle and its magnitude is dependent on the object's speed and the radius of the circle.
3. How is centripetal acceleration related to vertical circles?
In a vertical circle, the centripetal acceleration is responsible for keeping the object moving in a circular path. This is because the force of gravity is constantly pulling the object towards the center of the circle, providing the necessary centripetal force.
4. What factors affect centripetal acceleration in vertical circles?
The two main factors that affect centripetal acceleration in vertical circles are the object's speed and the radius of the circle. A higher speed or a smaller radius will result in a greater centripetal acceleration.
5. How is centripetal acceleration calculated in vertical circles?
The formula for calculating centripetal acceleration in vertical circles is: a = v^2/r, where a is the centripetal acceleration, v is the speed of the object, and r is the radius of the circle. This formula can also be rearranged to find the speed or radius given the other two values.
