Vertical circuit under a magnetic field
In summary: The electrical power is ##P = \epsilon I_{circuit} = \frac{\epsilon^2}{2R+2\beta l} = \frac{(\mu_0 I)^2}{2\pi R}\frac{ln^2(1+\frac{b}{a})}{2R+2\beta l}##. This must equal ##Fv_0##. So the force is ##F = \frac{(\mu_0 I)^2}{2\pi R}\frac{ln^2(1+\frac{b}{a})}{(2R+2\beta l)v_0}##. I think this is the same as you have, but you
carllacan
274
An undefinedly long circuit is set vertically besides a current wire. The circuit has a conducting straight wire (the line AB) that can slide over it. The segments AB and CD have both resistance R, and the rest of the circuit has a lineal resistance ##\beta##.
How much force do we need to apply to the segment AB so that it descends with constante velocity ##v_0##?
https://photos-1.dropbox.com/t/2/AABqrUoB2O4vc616FYj-7SjoKBE3HfVok5fdrE-mQjBsEA/12/28182931/png/1024x768/3/1422032400/0/2/Screenshot%20from%202015-01-23%2015%3A34%3A30.png/CJOTuA0gASACIAMoASgC/SZ8-4VjvN-JRevQHpIByWWJh9zKoEmwluexW0MgzuiQ
Magnetic field of a straight wire ## \vec B = \frac{\mu_0 I}{2\pi r} ##
Faraday's law of induction ##\epsilon = - \frac{d\Phi}{dt}##
The first things I've done is find the expression for the magnetic flux through the circuit. I'll call ##l## the distance between the points C and A. To do so I integrate the magnetic field created by the wire at a distance r from a to a+b, and then multiply it by the height of the closed circuit, which is l.
## \Phi = l\int _{a} ^{a+b} B_{wire}(R) dR = l\int \frac{\mu_0 I}{2\pi R} dR = \frac{\mu_0 I l}{2\pi} (ln|a+b| -ln|a|) =l \frac{\mu_0 I }{2\pi} ln|1+\frac{b}{a}|##
Now the EMF on the circuit is simply
## \epsilon = - v\frac{d\Phi}{dt} = -\frac{\mu_0 I }{2\pi} ln|1+\frac{b}{a}|##, where ##v## is the velocity at which l grows, or equivalently the falling velocity of the wire.
Next I need the current along the segment, and here is where I start running into problems, since I'm not sure of how to treat the EMF in a circuit. I know it is a voltage, but when I normally work with circuits voltage are defined between two points in a circuit. Between which two points should I put ##\epsilon##? Between any pair of points? Or should I divide ##\epsilon## by the total resistance of the circuit and take the result as a current through it? That is ##I_{circuit}=\frac{V}{R_T}= \frac{\epsilon}{2R+2\beta l} ##
Thank you for your time.
Looks like you have the ##v## misplaced, but I think it's just a typo.
Yes. Divide the induced emf by the total circuit resistance.
Thanks. Now to find the magnetic force on the moving segment I would need to integrate ##F = \int _a ^{a+b}\vec I_c \times \vec B(r)dr = -I_c\int _a ^{a+b}\vec e_x \times \vec e_z B(r)dr =-I_c\int _a ^{a+b}\vec e_y\frac{\mu_0 I_{wire}}{2\pi r}dr = \frac{\mu_0 i_c I_{wire}}{2\pi }ln(\frac{a+b}{a})\vec e_y ## right?
Yes, that looks right. (I'm not quite sure on the orientation of your coordinate axes. Therefore, I'm not sure how to interpret the direction of your force. In your next to last expression there is a negative sign that seems to disappear in the last expression.) There's a quicker way to get F from energy considerations. The electrical power consumed in the circuit must match the mechanical power input by the applied force F.
I would like to start by commending you on your thorough approach to solving this problem. Your calculation of the magnetic flux and EMF are correct, and you have identified a key issue in determining the current along the segment AB.
In this scenario, the EMF acts as a voltage source in the circuit, meaning it will drive a current through the circuit. However, as you have pointed out, it is not clear between which two points in the circuit the EMF should be applied. In this case, I would suggest treating the EMF as a voltage source between points A and C, since these are the two points directly affected by the magnetic field and are also connected by the sliding wire.
Using this approach, the current through the circuit can be calculated using Ohm's Law: ##I = \frac{\epsilon}{R_T}##, where ##R_T## is the total resistance of the circuit. This will give you the current through the circuit, which will also be the current through the segment AB.
To determine the force required to maintain a constant velocity of ##v_0##, you can use the equation ##F = ILB##, where L is the length of the segment AB and B is the magnetic field strength. This will give you the force required to counteract the magnetic force on the wire and maintain a constant velocity.
Overall, your approach is sound and with the adjustment of treating the EMF as a voltage source between points A and C, you should be able to solve this problem successfully. Good luck!
Related to Vertical circuit under a magnetic field
1. What is a vertical circuit under a magnetic field?
A vertical circuit under a magnetic field refers to a circuit that is positioned vertically in relation to a magnetic field. This means that the magnetic field is acting perpendicular to the plane of the circuit and can cause changes in the circuit's behavior.
2. How does a magnetic field affect a vertical circuit?
A magnetic field can induce an electric current in a vertical circuit through electromagnetic induction. This occurs when the magnetic field lines cut across the circuit, creating a potential difference and causing electrons to flow in the circuit.
3. What is the purpose of a vertical circuit under a magnetic field?
A vertical circuit under a magnetic field is often used in experiments to demonstrate the effects of electromagnetic induction. It can also be used in practical applications such as generators and motors, where the changing magnetic field induces a current to produce motion.
4. How can the behavior of a vertical circuit under a magnetic field be controlled?
The behavior of a vertical circuit under a magnetic field can be controlled by changing the strength or direction of the magnetic field, as well as the properties of the circuit, such as its resistance and inductance. This allows for variations in the induced current and the overall behavior of the circuit.
5. Are there any real-life examples of vertical circuits under a magnetic field?
Yes, there are many real-life examples of vertical circuits under a magnetic field. Some common ones include transformers, generators, motors, and electromagnetic brakes. These devices utilize the principles of electromagnetic induction to function and are essential in many industries and technologies.
