Vertical displacement of electron
In summary, an electron with a horizontal speed of 1.9 × 10^7 m/s is acted upon by a constant vertical force of 4.3 × 10^-16 N in a region. With a mass of 9.11 × 10^-31 kg, the electron moves a horizontal distance of 34 mm. Using the equations F=ma and x-x.o=v.ot+(1/2)a*t^2, the vertical displacement is found to be 0.034 meters. However, when using the value of 4.72 × 10^14 m/s^2 for acceleration, the incorrect value of 0.000002 seconds is obtained. To find the correct value of t, the
willson.slp
An electron with a speed of 1.9 × 107 m/s moves horizontally into a region where a constant vertical force of 4.3 × 10-16 N acts on it. The mass of the electron is 9.11 × 10-31 kg. Determine the vertical distance the electron is deflected during the time it has moved 34 mm horizontally.
(btw the answer is in meters)
F=ma
a=F/m
y-y.o=v.o yt-(1/2)at^t
I've gotton completely lost on this. First I solved for acceleration and got 4.72E14 m/s^2. Next I used that to find time using the horizontal displacement formula and got t=1.20027E-8. When i plugged all that into find the vertical displacement I got .034meters which was incorrect. I ve tried a few other ways but to no avail. Any help would be great.
Thanks
Your method is correct, but t is not equal to 1.20027E-8 s. What value did you use for "a" in the horizontal displacement formula? It should be 0 because there's no horizontal force.
When I used a=F/m I got (4.3E-16)/9.11E-31) which equals 4.72E14
when I try a=0 in the horzizontal displacement formula, I got t= .000002
Do I use that in the vertical diplacement formula for t and then 4.72E14 for a?
There are two problems with that answer:
1. Did you use 34 m or 34 mm for the horizontal distance?
2. Your answer has just 1 significant figure, but it should have 2 significant figures.
Yes, once you get the correct value of t, use it and 4.72e14 m/s2. Important: what is the vertical component of the initial velocity?
for your question! To solve this problem, we need to use the equations of motion to determine the vertical displacement of the electron. First, let's find the acceleration of the electron in the vertical direction using the formula F=ma. We know that the force acting on the electron is 4.3 × 10-16 N, and the mass of the electron is 9.11 × 10-31 kg. Plugging these values into the formula, we get:
a = F/m = (4.3 × 10-16 N)/(9.11 × 10-31 kg) = 4.72 × 1014 m/s2
Next, we can use the equation y-yo = vyo*t - (1/2)*a*t^2 to find the vertical displacement of the electron. We know that the initial velocity in the y-direction (vyo) is 0, since the electron is initially moving horizontally. We also know that the time (t) is 1.20027 × 10-8 s, as you calculated. Plugging in these values, we get:
y-yo = 0 - (1/2)*(4.72 × 1014 m/s2)*(1.20027 × 10-8 s)^2 = -3.22 × 10-17 m
This is a very small displacement, which makes sense since the electron is initially moving horizontally and the force acting on it is very small. Therefore, the vertical displacement of the electron during the time it has moved 34 mm horizontally is approximately 0 meters. I hope this helps!
Related to Vertical displacement of electron
What is vertical displacement of electron?
Vertical displacement of electron refers to the movement of an electron in the vertical direction, perpendicular to the horizontal plane.
Why is vertical displacement of electron important in science?
Vertical displacement of electron is important in science because it plays a crucial role in understanding the behavior and properties of electrons in various physical systems, such as in electronic devices and in the study of atomic and molecular structures.
What factors affect the vertical displacement of electron?
The vertical displacement of electron can be affected by external forces, such as electric and magnetic fields, as well as by the properties of the material the electron is moving through, such as its density and conductivity.
How is vertical displacement of electron related to energy levels?
The vertical displacement of electron is closely related to the energy levels of electrons in an atom. When an electron moves vertically, it changes energy levels, either gaining or losing energy in the process.
What are some applications of studying vertical displacement of electron?
Studying vertical displacement of electron has many practical applications, including in the development of new electronic devices, understanding the structure and properties of materials, and in the field of quantum mechanics.
