brotherbobby
- 699
- 163
- Homework Statement
- A ball is thrown vertically up with some initial velocity. If the resistance due to air (air drag) creates an additional acceleration equal to a tenth of the acceleration due to gravity (##g = 10\; \text{m/s}^2##) :
(a) calculate the percentage change in the ball's total time of flight,
(b) argue whether the ball takes more or less time to be in flight due to air resistance.
- Relevant Equations
- Total time of flight for a ball thrown vertically up with a velocity ##v_0## is ##T = \frac{2v_0}{g}## where ##g## is the acceleration due to gravity.
Attempt : The total time of flight in free space : ##T = \frac{2v_0}{g}##.
On its way up in air, ##T'_{\text{up}} = \frac{v_0}{g+g_a} = \frac{v_0}{g+\frac{g}{10}} = \frac{v_0}{\frac{11g}{10}} = \frac{10 v_0}{11 g}##.
On its way down in air, ##T'_{\text{down}} = \frac{v_0}{g-g_a} = \frac{v_0}{g-\frac{g}{10}} = \frac{v_0}{\frac{9g}{10}} = \frac{10 v_0}{9 g}##.
Total time of flight in air : ##T' = \frac{10v_0}{g} \left(\frac{1}{9} + \frac{1}{11}\right) = \frac{10v_0}{g} \frac{20}{99} = \frac{200}{99} \frac{v_0}{g}##.
Difference in times : ##\Delta T = T'-T = \frac{v_0}{g}\left( \frac{200}{99} - 2 \right) = \frac{2}{99} \frac{v_0}{g} = \frac{1}{99}T##.
(a) The percentage change in the ball's time of flight : ##\Delta T##% = ##\frac{\Delta T}{T}\times 100 = \frac{100}{99} = \boxed{1.01\%}##.
(b) The ball takes more time in flight due to air resistance since ##T'>T##. Of course it travels the same distance either way. It takes less time to rise and a greater time to fall than without air resistance - facts which are both counter intuitive. Exactly as to why ##T'>T## qualitatively, I do not know. Clearly the (absolute value) of acceleration on its way up (##\frac{11g}{10}##) exceeds ##g## by a value ##\left(\frac{g}{10} \right)## which is the same as the amount by which ##g## exceeds it on its way down : ##g-\frac{9g}{10} =\frac{g}{10}##. By that argument, the two times should make up when they add and the ball should have the same times of flight with or without air, but it does not.
Any help would be welcome. I suppose I have got the body of the argument correct, but not the tricky bit towards the end where I can't explain why is ##T'>T## qualitatively.
