MHB Vertical / Horizontal Displacements
The discussion centers on a math problem involving the trajectory of a kicked ball, modeled by the equation y=3x - x^2/2. The main questions are to find the maximum vertical displacement and to determine if the ball clears a 3-meter wall located 5 meters away. The poster expresses difficulty in understanding the math, particularly in solving the problem efficiently. Key points include the need to identify the vertex of the parabola for maximum height and to calculate the vertical displacement at x=5 to assess the wall clearance. This highlights the challenges faced by those returning to mathematics after a long gap.
JJKD
Hey guys! Firstly, let me start by apologizing if this is completely the wrong place to put this question. As you'll soon tell my maths is... well, questionable at best.
Let me just give some context to avoid any assumptions :) I'm starting an OU degree in autumn with my first module being mathematics. My maths knowledge didn't get any further than high school so it's a bit of a challenge. I've been trying to revise using practise papers and bring myself at least up to scratch but this is proving difficult. There are some questions where I'm spending hours on them which would take some of you 10 minutes. But this question here is driving me nuts...
The question:
A boy standing on a level playing field kicks a ball into the air from the
ground at his feet. The trajectory of the ball can be modeled by the
equation
y=3x - x^2/2
where x is the horizontal displacement (in metres) of the ball from the
boy and y is the vertical displacement (in metres) measured from the
ground.
(i) Find the maximum vertical displacement of the ball.
(ii) If there is a 3 metre high wall at a distance of 5 metres from the
boy, in the direction the ball is travelling, will the ball be kicked
over the wall? Explain your answer.​
I have lots more questions like this but I want to work those out myself when I have an understanding of the first one :/
Sorry this is a pretty big 'text dump', but my math ability is pretty bad and I don't even know where to begin.
Cheers guys!
Jay
Mathematics news on Phys.org
(i) What does the $y$-coordinate of the vertex of the parabola represent?
(ii) What is the value of $y$ when $x$ is 5?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
