Vertical motion Velocity and Acceleration dot products
In summary, the conversation discusses the dot product of velocity and acceleration in the vertical motion of a ball without air resistance. It is determined that the dot product can be zero, negative, or positive depending on the direction of motion and the direction defined as positive. It is also discussed in the case of parabolic motion, the dot product will always be zero at the point where the ball reaches its maximum height.
Mathias
A ball is tossed straight up into the air so that it moves in the vertical direction without air resistance. Is there a point where the dot product of the velocity with the acceleration is:
a. Zero
b. Negative
c. Positive
d. now assume the ball moves in a parabolic path without air resistance. Is there a point where the dot product of the velocity with the acceleration is zero.
Explain your answers.
We know that, in vertical motion both ##v_x## and ##a_x = 0##
We know that in parabolic motion ##a_x = 0##
Dot Product ## (v_x , v_y) \cdot (a_x, a_y) ## -> ##(v_x * a_x) + (v_y * a_y)##
My Assumptions:
  • if y-direction is upwards accleration due to gravity is negative ##a_y=-9.81m/s^2##
  • Velocity when ball is thrown up is positive, and when the ball comes back down the velocity is negative due to change in direction, magnitude is the absolute value so the speed is never negative it is the direction.
  • if y-direction is downwards acceleration due to gravity is positive ##a_y=+9.81m/s^2##
a. Yes, Assuming y-direction of upwards is positive; ##(0 , v_y) \cdot (0 , a_y)## -> ##(0*0)+(v_y * a_y)## -> ##(v_y * -9.81m/s^2)## -> v_y = 0 at the instant it reaches max height, before the ball travels downwards -> ##(0m/s*-9.81m/s^2)## -> yields value of 0
b. Yes, Assuming y-direction of upwards is positive; ##(0 , v_y) \cdot (0 , a_y)## -> ##(0*0)+(v_y * a_y)## -> ##(v_y * -9.81m/s^2)## -> v_y = positive when thrown up, -> ##(+m/s*-9.81m/s^2)## -> yields negative value
c. Yes, Assuming y-direction downward is positive ##(0 , v_y) \cdot (0 , a_y)## -> ##(0*0)+(v_y * a_y)##, -> ##(v_y * 9.81m/s^2)## -> v_y is positive when falling back down, -> ##(+m/s*9.81m/s^2)## -> yields positive value
d. Yes, assuming y-direction upward is positive, and x-direction to the right is positive. ##(v_x , v_y) \cdot (0, -9.81)## -> no matter the velocity of x the product of x and 0 is still 0 -> ##(v_x*0)+(v_y*-9.81m/s^2)## -> we know that at max height instantaneous velocity of y is zero -> ##(0*0)+(0*a_x)## -> the dot product yield zero
I'm not sure if my logic/assumptions are correct in regards to c. and d. where the reason why velocity changes is because the direction changes, and when defining y downwards as positive if velocity when the ball is going up if it is positive then, or when it is coming down.
All good.
Related to Vertical motion Velocity and Acceleration dot products
What is vertical motion velocity?
Vertical motion velocity refers to the speed at which an object is moving in a vertical direction. It is a measure of the displacement over time and is typically measured in meters per second (m/s).
What is acceleration in vertical motion?
Acceleration in vertical motion is the rate of change of velocity in the vertical direction. It is typically measured in meters per second squared (m/s^2) and can be positive (increasing velocity) or negative (decreasing velocity).
How do dot products relate to vertical motion velocity and acceleration?
In the context of vertical motion, dot products are used to calculate the angle between the velocity and acceleration vectors. This angle can provide information about the direction and magnitude of the acceleration in relation to the velocity.
What is the significance of a positive dot product in vertical motion?
A positive dot product in vertical motion indicates that the velocity and acceleration vectors are in the same direction. This means that the object is either speeding up if both vectors are positive, or slowing down if both vectors are negative.
What is the significance of a negative dot product in vertical motion?
A negative dot product in vertical motion indicates that the velocity and acceleration vectors are in opposite directions. This means that the object is either slowing down if the acceleration vector is positive and the velocity vector is negative, or speeding up if the acceleration vector is negative and the velocity vector is positive.
