Very basic question on derivative notation
In summary, the notation for a derivative is dy/dx, where y is the dependent variable and x is the independent variable. It is read as "the derivative of y with respect to x" and the symbol d/dx represents the derivative operator. To find the derivative of a function using notation, you can use the formula dy/dx = lim(h->0) [f(x+h) - f(x)] / h, also known as the limit definition of a derivative. Other letters can also be used to represent variables in derivative notation, such as df/dt representing the derivative of f with respect to t.
ledphones
could B d/dt (x1 -x2) be equal to B (dot{x}1 - dot{x} 2)? Thank you!
dot{x} is supposed to be a "dot" over a x. Just a formatting problem
The derivative is a linear operator, so the following properties hold:
  1. [itex]\displaystyle\frac{\text{d}}{\text{d}t}\!\left(\alpha x\right) = \alpha\dot{x}[/itex]
  2. [itex]\displaystyle\frac{\text{d}}{\text{d}t}\!\left(x_1 + x_2\right) = \dot{x}_1 + \dot{x}_2[/itex]
Thank you!
FAQ: Very basic question on derivative notation
What is the notation for a derivative?
The notation for a derivative is dy/dx, where y is the dependent variable and x is the independent variable.
How do you read a derivative notation?
The derivative notation dy/dx is read as "the derivative of y with respect to x."
What does the symbol d/dx mean in derivative notation?
The symbol d/dx represents the derivative operator, which is used to find the rate of change of a function with respect to its independent variable.
How do you find the derivative using notation?
To find the derivative of a function f(x) using notation, you can use the formula dy/dx = lim(h->0) [f(x+h) - f(x)] / h. This is known as the limit definition of a derivative.
Can you use other letters besides x and y in derivative notation?
Yes, you can use any letters to represent variables in derivative notation. For example, df/dt represents the derivative of f with respect to t.
