(Very) Basic Questions on Linear Transformations and Their Matrices
In summary, a matrix representation of a linear transformation depends on the choice of basis. Similarly, the coordinates of a vector also depend on the choice of basis. The standard basis is commonly used to represent elements of a field. A vector space does not have a basis inherently, it is chosen by convention. There is no unique matrix representation of a linear transformation, as it depends on the choice of bases for the vector spaces involved. Bases are useful for calculating with vectors, but are not inherent to the vector space itself.
Math Amateur
MHB
3,998
48
Firstly, my apologies to Deveno in the event that he has already answered these questions in a previous post ...
Now ...
Suppose we have a linear transformation \(\displaystyle T: \mathbb{R}^3 \longrightarrow \mathbb{R}^2\) , say ...
Suppose also that \(\displaystyle \mathbb{R}^3\) has basis \(\displaystyle B\) and \(\displaystyle \mathbb{R}^2\) has basis \(\displaystyle B'\), neither of which is the standard basis ...
Suppose further that \(\displaystyle T(x, y, z) = ( x + 2y - z , 3x + 5z )\) ... ...
Then (if I am right) we write the matrix \(\displaystyle A\), of the transformation as follows:
\(\displaystyle A = \begin{bmatrix} 1 & 2 & -1 \\ 3 & 0 & 5 \end{bmatrix}\)... BUT ... questions ...Question 1
Is the expression for the linear transformation
an expression in terms of the transformation of \(\displaystyle v = (x, y, z)\) into \(\displaystyle w = T(v)\) in terms of the bases \(\displaystyle B\) and \(\displaystyle B'\) ... ...
That is, when we input some vector \(\displaystyle v = ( 2, 1, -3 )\) , say ... ... is that vector to be read as being in terms of the basis \(\displaystyle B\) or in terms of the standard basis ... ...
... ... and is the output vector from applying T, namely
\(\displaystyle T(v) = ( 2, 1, 3 ) = ( x + 2y - z , 3x + 5z ) = ( 2 + 2(1) - (-3) , 3(2) + 5(-3) ) = ( 7, -9 )\)
in terms of the basis \(\displaystyle B'\) or in terms of the standard basis?[By the way, I think it is, by convention, that linear transformations from \(\displaystyle \mathbb{R}^n\) to \(\displaystyle \mathbb{R}^m\) are expressed as if they are from a standard basis to a standard basis ... but why they are not taken to be in the declared bases \(\displaystyle B\) and \(\displaystyle B'\), I am not sure ... ... ]
Question 2
Does the matrix of the transformation
represent the transformation from \(\displaystyle [v]_B\) to \(\displaystyle [T(v)]_{B'}\)
or
does it represent the transformation from \(\displaystyle [v]_{S_1}\) to \(\displaystyle [T(v)]_{S_2}\)
where \(\displaystyle S_1\) is the standard basis for \(\displaystyle \mathbb{R}^3\)
and \(\displaystyle S_2\) is the standard basis for \(\displaystyle \mathbb{R}^2\)
Hope someone can help ...
Peter
A matrix representation of a linear transformation DEPENDS on the basis chosen.
In the same vein, the COORDINATES of a vector ALSO depend on the basis chosen.
By itself, the triple $(2,0,5)$ means nothing-it is just three numbers separated by commas, and enclosed in parentheses.
By convention (and *solely* by convention), elements of $F^n$ (where $F$ is any field) are usually denoted by their representation in the standard basis:
$e_1 = (1,0,\dots,0)$
$e_2 = (0,1,\dots,0)$
$\vdots$
$e_n = (0,0,\dots,1)$so when we say, $(x,y,z) \in \Bbb R^3$, for example, what we really MEAN is, the linear combination:
$xe_1 + ye_2 + ze_3$.
Given an $n$-dimensional vector space, the only point unambiguously defined by an $n$-tuple is the $0$-vector, which is the same in any basis. For example, the point in $3$-space you may think of as the $x$-unit vector ($e_1$) might be what I think of as $(\frac{\sqrt{2}}{2},\frac{\sqrt{2}}{2},0)$, because my $3$-space has the $xy$-plane rotated 45 degrees.
Given a linear transformation, there isn't THE matrix representation, only *A* linear representation *relative to some choice of bases*. Indeed there is a linear isomorphism from:
$\text{Hom}_F(U,V) \to \text{Mat}_{\dim(V) \times \dim(U)}(F)$
but this isomorphism isn't unique, we get a different one for each pair of bases chosen for $U$ and $V$.
Bases are a great way to turn our calculations with vectors into calculations in the underlying field-but a vector space doesn't "come" with a basis supplied (it doesn't care what coordinate system you choose).
$\vdots$
Well! ... ... That was REALLY HELPFUL!
Thanks Deveno ... that has cleared a few things up for me ...
Thanks again,
Peter
FAQ: (Very) Basic Questions on Linear Transformations and Their Matrices
What is a linear transformation?
A linear transformation is a mathematical operation that maps one vector space onto another, without changing the dimension of the space. It preserves the basic structure and properties of the space, such as linearity, parallelism, and distances between points.
What is a matrix in the context of linear transformations?
A matrix is a rectangular array of numbers that represents a linear transformation between two vector spaces. The columns of the matrix correspond to the basis vectors of the input space, and the rows correspond to the basis vectors of the output space.
What is the difference between a linear transformation and a matrix?
A linear transformation is an abstract mathematical concept, while a matrix is a concrete representation of that concept. A linear transformation can be represented by many different matrices, depending on the basis vectors chosen for the input and output spaces.
How do you determine the matrix of a linear transformation?
To determine the matrix of a linear transformation, you first need to choose a basis for the input and output spaces. Then, you apply the linear transformation to each basis vector of the input space and express the resulting vectors in terms of the basis vectors of the output space. These resulting vectors form the columns of the matrix.
What is the importance of linear transformations and their matrices?
Linear transformations and their matrices are essential tools in mathematics, physics, engineering, and many other fields. They allow us to study and understand complex systems by simplifying them into more manageable forms. They also have practical applications, such as in computer graphics, machine learning, and data compression.
