Very brief explanation please? - Newt 2nd Law w/ Circular Motion
In summary, the conversation discusses how to find the radial acceleration of a weight on a conical pendulum. The equation used is ar = (Tsin@)/m, but the question arises as to why it is Tsin@ instead of Tcos@. It is explained that Tsin@ gives the perpendicular force to the radial acceleration, while Tcos@ gives the parallel force. The confusion is cleared up when it is realized that the pendulum is conical and not a regular 2-D pendulum.
mc8569
25
Consider a conical pendulum with a weight on it and that makes some angle with the vertical. I am told to find the radial acceleration of the weight and someone showed me how it is solved but I don't understand why:
I am told to set
Tsin@ = m(ar) *ar = radial acceleration
ar = (Tsin@)/m
I was wondering why it would be T*SIN* instead of T*COS*? Tcos@ would give you the force that is parallel with radial acceleration, Tsin@ gives you a force that is perpendicular to the radial acceleration... Please help me! I don't understand this - only should take a few seconds. Thanks! XP
AHHHH OHHH NEVERMIND! Sorry... *CONICAL* pendulum, lol I was thinking of a regular, 2-D pendulum. I would delete this if I could, but I can't =\ But no need to respond anyone! So silly!
The reason for using T*sin@ instead of T*cos@ is because in circular motion, the acceleration is always perpendicular to the velocity. In this case, the weight on the conical pendulum is moving in a circular path and the acceleration is directed towards the center of the circle. The tension force, T, is acting at an angle @ with respect to the vertical, but only the component of T that is perpendicular to the radial acceleration, which is T*sin@, is responsible for causing the circular motion. The component of T that is parallel to the radial acceleration, which is T*cos@, does not contribute to the circular motion and is therefore not used in the equation. I hope this helps clarify the reasoning behind using T*sin@ for finding the radial acceleration in this scenario.
FAQ: Very brief explanation please? - Newt 2nd Law w/ Circular Motion
What is the Newt 2nd Law?
The Newt 2nd Law, also known as Newton's Second Law of Motion, states that the acceleration of an object is directly proportional to the net force acting on the object and inversely proportional to its mass. In simpler terms, the more force applied to an object, the more it will accelerate, and the heavier the object, the less it will accelerate.
How does the Newt 2nd Law apply to circular motion?
The Newt 2nd Law can be applied to circular motion by considering the centripetal force, which is the force that keeps an object moving in a circular path. According to the law, the centripetal force is equal to the mass of the object multiplied by its centripetal acceleration.
What is circular motion?
Circular motion is the movement of an object along a circular path. This type of motion is characterized by a constant speed but changing direction, as the object continuously moves along the circumference of the circle.
Can circular motion exist without a force?
No, circular motion cannot exist without a force. According to the Newt 2nd Law, there must be a force acting on an object in order for it to accelerate. In the case of circular motion, the centripetal force is necessary to keep the object moving in a circular path.
How is circular motion different from linear motion?
Circular motion is different from linear motion as it involves a constant change in direction, whereas linear motion involves movement in a straight line. Additionally, circular motion requires a centripetal force, while linear motion may or may not have a force acting on the object.
