Very important question in switched cap integrator
  • Thread starter hoka_89
  • Tags
    Important
In summary, the conversation discusses the need to put a DC input on a switched capacitor integrator and how to incorporate a DAC and feedback bits to control switches in a sigma delta modulator. The speaker is seeking help for their graduation project and the conversation has been moved to the Homework Help, Engineering forum. Further clarification is needed on terms such as "a switched capacitor integrator" and "a sigma delta modulator" for better understanding and assistance.
hoka_89
first:
i want to put a dc input on a switched capacitor integrator how can i do this
second i make a sigma delta modulator and iwant to put the dac in the integrator and make the feed back bits to control the switches how can i do this
please i want anyone to replay to me
hoka_89 said:
first:
Welcome to the PF.
What is the application? Is this for schoolwork?
it is a graduation project
Sounds like fun. I've moved the thread to the Homework Help, Engineering forum, which is where it belongs.
Now, can you please define some terms that you are using? At least to me, the terms are a bit off (it could be part of the language translation, or just a misunderstanding on my part or your part of the technical terms). Please write a bit about these:
** "a switched capacitor integrator"
** "a sigma delta modulator"
Once you define these a bit better, we may be able to offer some hints or pointers to sources of information to help you with your projects.
Hello,
Thank you for your question. In order to put a DC input on a switched capacitor integrator, you can use a DC-blocking capacitor in series with the input. This will block the DC component while allowing the AC component to pass through and be integrated.
As for using a sigma delta modulator with a DAC in the integrator, you can use the DAC to generate the feedback bits for the switches by connecting the output of the DAC to the control inputs of the switches. This will allow the switches to be controlled by the digital output of the sigma delta modulator, which can then be integrated by the integrator.
I hope this helps. Please feel free to ask any follow-up questions. Thank you.
FAQ: Very important question in switched cap integrator
What is a switched cap integrator?
A switched cap integrator is an electronic circuit that performs mathematical integration on an input signal. It is commonly used in analog-to-digital converters and sample-and-hold circuits.
How does a switched cap integrator work?
A switched cap integrator works by using a series of switches to alternate between charging and discharging a capacitor. The input signal is integrated by summing the charge on the capacitor over multiple switching cycles.
What are the advantages of using a switched cap integrator?
One of the main advantages of a switched cap integrator is its ability to reduce noise and offset errors in the signal. It also has a lower power consumption compared to other integration techniques and can be easily implemented in integrated circuits.
What are the limitations of a switched cap integrator?
One limitation of a switched cap integrator is its limited bandwidth due to the switching frequency and the capacitance values used. It also has a limited dynamic range and can be affected by parasitic capacitance and charge injection.
How is a switched cap integrator different from other integration techniques?
Unlike other integration techniques such as op-amp integrators, a switched cap integrator does not rely on resistors and capacitors for integration. Instead, it uses a series of switches and a capacitor to perform the integration, making it more suitable for integration in integrated circuits.
