Very silly question on whether the domain of ##log_{10}(x²)## = ##2log_{10}(x)##
  • Thread starter Thread starter tellmesomething
    Function
The discussion centers on finding the x-intercepts of the function log_{10}(x²) and its simplified form 2log_{10}(x). The original function yields x-intercepts at x = -1 and x = 1, while the simplified version only gives x = 1. It is clarified that the correct simplification should be 2log_{10}(|x|), which retains the intercepts of the original function. The conclusion emphasizes that both forms ultimately have the same x-intercepts when considering the absolute value.
tellmesomething
Title
Title
So say I have to find the x intercept of this function $$log_{10}(x²)$$ I get x={-1,1}.
But if I try to find the x intercept of this same function after simplifying I get $$2log_{10} (x)$$ I get x={1}
tellmesomething said:
Homework Statement: Title
Relevant Equations: Title
But if I try to find the x intercept of this ## same function## after simplifying I get $$2log_{10} (x)$$ I get x={1}
After simplifying, you get ##2log_{10} (|x|)## rather than ##2log_{10} (x)##, which has the same intercept as the original function.
Okay then :-)
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
