Why Can't I Simplify This Derivative Correctly?
  • Thread starter calisoca
  • Tags
    Stupid
In summary, the conversation discusses a student's attempt to solve a calculus problem involving finding the critical points of a function. The student struggles with simplifying the derivative using the product rule and asks for help from others. The conversation ends with clarification on the correct answer and the student expressing gratitude for the assistance.
calisoca
28
I am trying to solve this basic calculus problem, but I can't figure out the last step. It doesn't make sense to me. I know I'm just being an idiot and not thinking of it. This actually has little to do with calculus and more to do with basic algebra. Doh!
The problems asks us to find the critical points of the function f(x) = x^3/5 * (4-x).
I've gotten down to this point:
f'(x) = (3(4-x) / 5x^2/5) - x^2/5.
However, the solution to the problem goes on to this:
f'(x) = (3(4-x) - 5x) / 5x^2/5
I cannot for the life of me see how they reduced it down to that answer.
Any help would be much appreciated!
The highlighted 2 should be a 3. Then you can factor out the x2/5
Your derivative is wrong.
Given that [tex]f(x) = (4 - x) x^\frac{3}{5}[/tex]
it's simpler to just multiply this out before taking the derivative.
[tex]f(x) = 4x^\frac{3}{5} - x^\frac{8}{5}[/tex]
[tex]f'(x) = \frac{12}{5}x^\frac{-2}{5} - \frac{8}{5}x^\frac{3}{5}[/tex]
[tex]= x^\frac{-2}{5} (\frac{12}{5} - \frac{8}{5}x)[/tex]
Now it's easy to find the critical point.
I didn't think you could multiply it out?
Don't you need to use the product rule to differentiate with respect to x?
Also, there was as typo above. The x^2/5 ought to have been x^3/5.
You can always simplify an expression before taking the derivative if this makes the calculation shorter... note that the derivative of x3/5 is 3/5 x-2/5
I'm obviously rusty on my algebra here, but I greatly appreciate the help you guys are providing. All of it has really helped push me in the right direction. Also, I didn't know you could simplify before differentiating like that. Thank you for showing me that.
I can see it if I simplify before hand; however, the professor is asking us to use the product rule. When I use the product rule, I can't see it, but I am getting closer.
So here is where I'm at:
I went from (3/5x^-2/5(4-x)) - x^3/5
to 3/5x^-2/5((4-x) - 5/3x).
This is close to the answer the book has of 3/5x^-2/5((4-x) - 5x).
My question is, how did 5/3x turn into 5x?
Please help us out here. If you're going to write expressions on a single line, use parentheses liberally. It's really hard to tell when you write -x^3/5 whether you are talking about [tex]\frac{-x^3}{5}[/tex] or [tex]-x^\frac{3}{5}[/tex], and that's a simple example.
For the example I used, write it as -x^(3/5)
I can see where the confusion is. My apologies.
So here is where I'm at, making liberal use of parenthesis:
I went from (((3/5)*(x^(-2/5)))*(4-x)) - (x^(3/5))
to ((3/5)*(x^(-2/5)))*((4-x) - ((5/3)*x))This is close to the answer the book has of ((3/5)*(x^(-2/5)))*((4-x) - 5x).
My question is, where did I go wrong by using ((5/3)*x), since the book has -5x? Or rather, how do I get to -5x from where I'm at?
If there is any further confusion, please let me know, and I will try to clarify as best as possible.
I am interpreting the answer you said in your previous post was the book's in this way:
[tex]\frac{3}{5} x^ \frac{-2}{5} (4 - x - 5x)[/tex]
This is not the right answer, and is in disagreement with what you said was the book's answer in your first post in this thread, namely
f'(x) = (3(4-x) - 5x) / 5x^(2/5) (I added parentheses around the exponent.)
This can be simplified to (12 - 3x - 5x)/(5x^(2/5)) = (12 - 8x)/(5x^(2/5))
This is the same as (4/5)(3 - 2x)/(x^(2/5)), and is equal to what I got using two techniques.
1. By multiplying first and then differentiating, I got
[tex]f'(x) = \frac{4}{5} x^ \frac{-2}{5} (3 - 2x)[/tex]
2. By using the product rule and then pulling out a common factor, I got
[tex]f'(x) = \frac{3}{5} x^ \frac{-2}{5} (4 - x ) - x^\frac{3}{5}[/tex]
[tex]= x^\frac{-2}{5} (\frac{3}{5} (4 - x ) - x)[/tex]
[tex]= x^\frac{-2}{5} (\frac{12}{5} - \frac{3}{5}x - x)[/tex]
[tex]= \frac{4}{5}x^\frac{-2}{5} (3 - 2x})[/tex]
Either of my answers could also be written as
[tex]f'(x) = \frac{8}{5}x^\frac{-2}{5} (1.5 - x})[/tex]
The two expression I ended with in each case is preferred since you can do something with it, namely find where f'(x) = 0.
Since I got the same answer using two different techniques, I'm pretty confident that I have the right answer. If your answer and/or the books answer can't be converted to look like mine, one or both of the answers you show are incorrect.
Yes, I see what I am looking for. I was making a very small and simple mistake in the factoring, but it obviously had big consequences for my answer.
I am not that particularly great at factoring, so this has really helped me.
I am working to get better, and you guys have helped me progress. Thank you.
Related to Why Can't I Simplify This Derivative Correctly?
What does "Very simple question. Yes, I'm stupid." mean?
"Very simple question. Yes, I'm stupid." is a phrase that is commonly used to indicate that the person speaking is asking a question that they feel is very basic and may make them seem unintelligent.
Why do people use the phrase "Very simple question. Yes, I'm stupid." when asking a question?
People may use this phrase when asking a question because they want to acknowledge that the question may seem obvious or basic to others. It can also be a way to show humility and a willingness to learn.
Is it okay to use the phrase "Very simple question. Yes, I'm stupid." in a professional setting?
Using this phrase in a professional setting may not be the best idea as it can come across as self-deprecating and may undermine your credibility. It is better to simply ask your question without making any assumptions about your intelligence.
What should I do if someone asks me a question and uses the phrase "Very simple question. Yes, I'm stupid."?
If someone asks you a question and uses this phrase, it is important to respond respectfully and without judgment. They may be genuinely seeking information and it is not helpful to make them feel embarrassed or foolish for asking.
Are there any other phrases or terms that I can use instead of "Very simple question. Yes, I'm stupid." when asking a question?
Yes, there are other phrases you can use to ask a question without implying that it is simple or making yourself seem unintelligent. For example, you could say "I have a question" or "Could you explain this to me?". These phrases are more neutral and do not carry any negative connotations.
