Very Simple Rotation Inertia of a Thin Rod Problem
In summary, to calculate the rotational inertia of a meter stick with mass 0.68 kg about an axis perpendicular to the stick and located at the 21 cm mark, you can use the parallel axis theorem if you know how to find the moment of inertia about the center of mass of the stick. This involves using the formula for the integral of radius squared with respect to mass.
Oijl
113
Calculate the rotational inertia of a meter stick, with mass 0.68 kg, about an axis perpendicular to the stick and located at the 21 cm mark. (Treat the stick as a thin rod.)
I = integral of radius squared with respect to mass
I'm not quite sure how to explain my issue here, but I think all I need is to see this worked out, and then I could probably understand the nature of these problems. Thanks.
You could use the parallel axis theoram if you know how to find the M.I about the centre of mass of the rod (the centre) :smile:
As a scientist, it is important to have a solid understanding of the concepts and equations being used in a problem. In this case, the rotational inertia of a thin rod can be calculated using the formula I = mr^2, where m is the mass of the rod and r is the distance from the axis of rotation to the center of mass of the rod.
In this problem, the mass of the meter stick is given as 0.68 kg. To find the distance, we need to consider the center of mass of the rod. Since the rod is uniform, the center of mass is located at the midpoint, which is 50 cm from either end. Therefore, the distance from the axis of rotation to the center of mass is 50 cm - 21 cm = 29 cm = 0.29 m.
Now, we can plug in the values into the formula: I = (0.68 kg)(0.29 m)^2 = 0.056 kgm^2. This is the rotational inertia of the meter stick about an axis perpendicular to the stick and located at the 21 cm mark.
It is important to note that this formula assumes the rod is a thin, uniform rod. If the rod has a non-uniform mass distribution or if it is not a thin rod, a different formula may need to be used. It is always important to carefully consider the assumptions and limitations of any formula being used in a problem.
FAQ: Very Simple Rotation Inertia of a Thin Rod Problem
What is the definition of rotational inertia?
Rotational inertia, also known as moment of inertia, is the measure of an object's resistance to rotational motion around a given axis. It depends on the mass and distribution of the object's mass around the axis of rotation.
How is rotational inertia different from mass?
Mass is a measure of an object's resistance to linear motion, while rotational inertia is a measure of its resistance to rotational motion. In other words, mass determines how difficult it is to change the object's velocity, while rotational inertia determines how difficult it is to change its rotational motion.
How is rotational inertia calculated for a thin rod?
The rotational inertia of a thin rod is calculated using the formula I = (1/12) * m * L^2, where I is the rotational inertia, m is the mass of the rod, and L is the length of the rod. This assumes that the rotation axis is at one end of the rod and the rod is rotating perpendicular to its length.
What factors affect the rotational inertia of a thin rod?
The rotational inertia of a thin rod is affected by its length, mass, and the distribution of its mass around the axis of rotation. Increasing any of these factors will result in an increase in rotational inertia, making it more difficult to rotate the rod.
How does rotational inertia affect the motion of a thin rod?
Rotational inertia affects the motion of a thin rod by determining how quickly it will rotate or how much torque is required to change its rotational speed. Higher rotational inertia means the rod will rotate slower and require more force to change its rotational motion.
10K
