faust9
- 692
- 2
The question:
A 2-kg point mass is welded on the interior of a 2-kg thin ring at point P. The ring has a radius R = 160 mm and rolls on the surface without slipping.
(a) Draw a free body diagram for the ring and point mass. Develop the equations of motion for the system.
(b) Combine the equations of motion derived in (a) into a single (nonlinear) ODE governing θ (t). Assuming a small angle θ (t), develop a linearized equation of motion for the system and calculate the natural frequency and also the free response when θ (0) = 25° and dθ/ dt (0) = 0.
With the origin placed at the center of the ring (axis of rotation), theta is measured from the -y axis in the ccw direction (from south to east if you will)
My approach:
(a) FBD was drawn.
Forces:
[tex]\vec N=N\hat J [/tex] Normal force acting up.
[tex]\vec W=-mg\hat J [/tex] weight force acting down from the center of mass.
[tex]\vec F_f=f\hat I [/tex] force of friction acting at the contact point.
Point C is defined as the center of mass
Point O is the origin
Point P is the point on the ring where the point mass is located
Point A is the point where the normal force and frictional forces act.
The point mass is on the ring thus the center of mass of the ring/mass body is at [itex]R/2[/itex]
[tex]\vec r_{C/O}=(\sin\theta\hat I-\cos\theta\hat J)R/2[/tex]
M=total mass=m1+m2
Acceleration of point C was determined thusly
[tex]\vec a_C=\vec a_O+ \ddot \theta \times \vec r_{C/O}-\dot \theta^2\vec r_{C/O} [/tex]
[tex]\vec a_O=\ddot \theta r \hat I [/tex]
[tex]\ddot \theta \times \vec r_{C/O}=\begin{vmatrix} \hat I & \hat J & \hat K\\ 0 & 0 & -\ddot \theta\\ \sin \theta R/2&-\cos \theta R/2& 0 \end{vmatrix}=-\ddot \theta\cos\theta R/2\hat I+\ddot\theta\sin\theta R/2\hat J [/tex]
[tex]-\dot \theta^2\vec r_{C/O}=-\dot \theta^2\sin\theta R/2\hat I+\dot \theta^2\cos\theta R/2\hat J [/tex]
Summing the forces and moments about C:
I: [tex]f=M(\ddot \theta R -\ddot \theta\cos\theta R/2-\dot \theta^2\sin\theta R/2)[/tex]
J: [tex]N-Mg=M(\ddot\theta\sin\theta R/2+\dot \theta^2\cos\theta R/2)[/tex]
K: [tex]f(1-\frac{\cos\theta}{2})R-N\sin\theta R=\ddot\theta I_T [/tex]
Two questions thus far: Is my approach correct and how do I determine the total moment of inertia([itex]I_T[/itex])?
Thanks
[edit] Silly me: the moment of inertia about c should be [itex]I_T=m_1R^2+m_1\frac{R^2}{4}+m_2R^2[/itex]
thus [tex]I_T=m\frac{9R^2}{4}[/tex] Is this correct?
My approach:
(a) FBD was drawn.
Forces:
M=total mass=m1+m2
Thanks
