benEE2018
- 27
- 1
Design a component that uses a 4-to-1 multiplexer to choose between one
of four different operations
to get the result from. Each of the operations and the multiplexer
should be behavioral design in their
own modules / files to be used in the overall component design as
separate components. The
component being design must use structural design to provide the inputs
to the components along with
getting their results.
The four operations expected are as follows:
- AND -- when selection bits are 00
- OR – when selection bits are 01
- XOR – when selection bits are 10
- NOT – when selection bits are 11
Each module is responsible for only 1 operation, so there should be a
total of five different modules /
components including the multiplexer being used in the overall component
design. Whenever a new
operation is selected or new inputs are provided to change the output of
the operations the multiplexer
should determine its new output.
Each of the operations can be assumed to only require two inputs, each 1
bit, to do the operations
except for the NOT operation, you can choose which input you want to
invert the logic of. The overall
component design should have two inputs, selections bits and an output.
Every gate in the design
should have a 3 ns delay, while NOT gates should have no delay.
it seems as my logic is correct but modelsim won't run my code and i don't know how to integrate the 3ns delay into my code.
library ieee;
use ieee.std_logic_1164.all
entity and is
port(i1,i2: in std_logic;
f1: out std_logic);
end entity and;
architecture and_beh of and is
begin
f1<= i1 and i2;
end architecture and_beh;library ieee;
entity or is
f2: out std_logic);
end entity or;
architecture or_beh of or is
begin
f2<= i1 or i2;
end architecture or_beh;
library ieee;
entity xor is
f3: out std_logic);
end entity xor;
architecture xor_beh of xor is
begin
f3<= i1 xor i2;
end architecture xor_beh;
library ieee;
entity not is
port(i1: in std_logic;
f4: out std_logic);
end entity not;
architecture not_beh of not is
begin
f4<= not i1;
end architecture not_beh;library ieee;
use ieee.std_logic_1164.all;
entity strct is
port(a,b: in std_logic;
f: out std_logic);
end entity strct;
architecture strct_beh of strct is
signal s1,s2,s3,s4: stf_logic;
component and is
f1: out std_logic);
end component and;
component or is
f2: out std_logic);
end component or;
component xor is
f3: out std_logic);
end component xor;
component not is
f4: out std_logic);
end component not;
begin
M1: and port map(i1=>a,i2=>b,f1=>s1);
M2: or port map(i1=>a,i2=>b,f2=>s2);
M3: xor port map(i1=>a,i2=>b,f3=>s3);
M4: not port map(i1=>a,f4=>s4);
end architecture strct_beh;
library ieee;
entity mxer is
port(s1,s2,s3,s4: in std_logic;
sel: in std_logic_vector(1downt
![Wacky o0) o0)](/styles/physicsforums/xenforo/smilies/wacky.png)
f5: out std_logic);
end entity mxer;
architecture mxer_beh of mxer is
signal sel: std_logic;
begin
process(s1,s2,s3,s4,sel)
begin
if(sel="00")then
f5<=s1;
elsif(sel="01")then
f5<=s2;
elsif(sel="10")then
f5<=s3;
elsif(sel="11")then
f5<=s4;
end if;
end process;
end architecture mxer_beh;
