Vibrations and Waves: Mass on Incline problem
In summary, the conversation discusses a system with a spring supporting a mass M on an incline with negligible friction. The value of M is given as 245 g and the length of the unstretched and stretched spring is also provided. The conversation then moves on to calculating the spring constant k and the oscillation frequency of the mass when given a small displacement. It is suggested to find the component of acceleration due to gravity along the inclined plane and use this to find the force and extension of the spring. The conversation ends with a final solution and gratitude for assistance.
huybinhs
230
A spring, of negligible mass and which obeys Hooke's Law, supports a mass M on an incline which has negligible friction. The figure below shows the system with mass M in its equilibrium position. The spring is attached to a fixed support at P. The spring in its relaxed state is also illustrated.
Pic link:
http://i995.photobucket.com/albums/af79/huybinhs/plot-2.png
a) Mass M has a value of 245 g. Calculate k, the spring constant.
b) The mass oscillates when given a small displacement from its equilibrium position along the incline. Calculate the oscillation frequency.
2. The attempt at a solution
I know that I need to find the component of the acceleration due to gravity along the inclined plane. From the graph I can find the sinθ. Then find the force which pulls the spring down. Find the extension of the spring and then k.
But I don't know how to get started (no ideas how to get numbers on the graph). Please be a guider! Thanks!
Length of the unstretched spring is 40 cm.
Length of the stretched spring is 50*sqrt(2) cm.
Thanks!
So, I got the length of the stretched spring is 70.7 cm.
In order to find k, I need to find F.
F = -mgsin(theta)
then I need to find sin(theta) first.
Could u let me know how to find sin(theta)?
sinθ = opposite side/ hypotenuse.
From the graph find these values.
Hypotenuse = sqrt[60^2+60^2] = sqrt7200 = 84.85
Sin(theta) = 60/84.85 = 0.707;
F = -1.700 N. Correct?
Got it all. Thanks so much rl.bhat ;)
FAQ: Vibrations and Waves: Mass on Incline problem
What is the Mass on Incline problem in vibrations and waves?
The Mass on Incline problem is a classic physics problem that involves a mass sliding down an inclined plane under the influence of gravity. It is commonly used to illustrate concepts related to forces, motion, and energy.
What are the key factors that affect the motion of the mass on an incline?
The key factors that affect the motion of the mass on an incline are the angle of the incline, the mass of the object, the force of gravity, and any external forces acting on the object.
How do vibrations and waves play a role in the Mass on Incline problem?
Vibrations and waves play a role in the Mass on Incline problem as they determine the frequency and amplitude of the oscillations of the mass as it slides down the incline.
What is the relationship between the angle of the incline and the acceleration of the mass?
The relationship between the angle of the incline and the acceleration of the mass can be described by the equation a = gsinθ, where a is the acceleration, g is the acceleration due to gravity, and θ is the angle of the incline.
How can the Mass on Incline problem be solved using principles of energy conservation?
The Mass on Incline problem can be solved using principles of energy conservation by considering the initial and final energies of the system, including potential energy and kinetic energy. By equating the two, the final velocity of the mass can be calculated and used to determine its motion along the incline.
