Virial equation, minimum pressure point
In summary, Option A seems to be the most sound, but I'm having trouble figuring out how to attack this problem.
MexChemE
237
55
Good evening PF! I'm having trouble figuring out how to attack this problem. I have tried two different ways but I don't know if either of them is correct.
Using the provided virial coefficients, determine analytically the pressure at which the graph of PV versus P for N2 at -50° C, reaches a minimum point.
Virial coefficients for N2 at -50° C:
A = 18.31
B = -2.88x10-2
C = 14.98x10-5
D = -14.47x10-8
E = 4.66x10-11
[tex]PV_m=A+BP+CP^2+DP^3+EP^4[/tex]
So, in order to find the minimum point I need two differentiate the function, and I'm trying two ways of doing this. I hope at least one of them is correct.
Option A:
[tex]\frac {d(PV_m)}{dP} = B+2CP+3DP^2+4EP^3[/tex]
In order to find the critical points I equate the above derivative to zero.
[tex]B+2CP+3DP^2+4EP^3 = 0[/tex]
Now I have to solve this cubic equation analytically, I could solve it with the help of a CAS, but the problem is asking for an analytic solution. This is as far as I can go. I did solve the equation with a software, and got two complex solutions and a real one. I assume the only solution that is relevant to me is the real one, right?
Option B:
I cleared Vm and expressed it as a function of P first, then differentiated.
[tex]V_m(P) = \frac{A}{P} +B+CP+DP^2+EP^3[/tex]
[tex]\frac{dV_m}{dP} = -\frac{A}{P^2} +C+2DP+3EP^2[/tex]
Equating to zero.
[tex]-\frac{A}{P^2}+C+2DP+3EP^2=0[/tex]
I have to solve this equation analytically too, but I have no idea with this one.
Well, I hope at least one of my procedures is right. Any help or insight will be greatly appreciated!
If PV is the quantity to be minimised then PV is what you must differentiate. dV/dP = 0 will find where V is minimised, which will be a different point.
There is an equation for solving cubics (Google it), but I'd be surprised if you were expected to know it or use it.
Yeah, option A seemed the most sound. I solved the equation with both WolframAlpha and Excel, the former gave me ~113 atm as a result, and the latter ~114 atm. Since this was the only real solution for the equation I'm assuming it is the minimum point I'm looking for and skipping the second derivative step. I also googled the equation you mentioned, I might try to solve it tomorrow. It's a LONG formula but it's just plug and chug. Thank you!
Now, I have a minor concern with notation, how should I denote the derivative of PV? d(PV) (applying product rule), VdP or PdV?
I would just leave it as d(PV). PV is the entity to be minimised.
"LONG" is way too mildly put. You will be surprised by how many pages you have to fill before you get to the solution (if ever).
It may be that by "analytically" they mean exactly what you did. They did not say find an analytic solution. What would be the point in giving you the values of the parameters, if this were what they mean?
But you could have just plotted the (PV) function and graphically estimate the minimum. This would be a graphical method.
Related to Virial equation, minimum pressure point
1. What is the Virial equation?
The Virial equation is an equation used in thermodynamics to describe the behavior of gases. It relates the pressure, volume, and temperature of a gas to its molecular properties.
2. How is the Virial equation derived?
The Virial equation is derived from the ideal gas law by accounting for the intermolecular forces between gas molecules. It includes a series of coefficients that depend on the specific gas being studied.
3. What is the minimum pressure point in the Virial equation?
The minimum pressure point in the Virial equation refers to the point at which the pressure of a gas is the lowest, or at its minimum value. This point typically occurs at high temperatures and low pressures.
4. How is the minimum pressure point determined in the Virial equation?
The minimum pressure point is determined by calculating the coefficients in the Virial equation and finding the point where the second coefficient, known as the second virial coefficient, is equal to zero.
5. What is the significance of the minimum pressure point in the Virial equation?
The minimum pressure point is important in understanding the behavior of gases at low pressures and high temperatures. It is also used in the development of more accurate equations of state for gases.
