Virtual displacement for a block sliding down a wedge
The discussion revolves around finding virtual displacements in a system where a block slides on a frictionless wedge, which can only move horizontally. Participants express confusion about how to apply the method of virtual displacement given the constraints of the system. It is noted that when the constraints are frozen, the block can only slide along the incline, yet some sources suggest the wedge also has a virtual displacement. A comparison is made to squeezing a slippery object to illustrate the interaction between the block and the wedge. The conversation highlights the need for clarity on applying virtual displacement methods in this context.
Kashmir
A block slides on a frictionless wedge which rests on a smooth horizontal plane. There are two constraints in this system. One that the wedge can only move horizontally and another that the block must remain in contact with the wedge.
We want to find the virtual displacements for the two block system.
To find those virtual displacements we imagine to freeze the constraints and look for the possible displacements.
Now if I freeze the constraints then the wedge cannot move. The only possible motion is that the small block slides parallal along the incline. However I have found on many articles online that there is a virtual displacement for the wedge as well.
This confuses me how to view the virtual displacements in this case. Can anyone please explain this. Thank you.
Imagine what happens if the small block is constrained to move vertically downwards. The wedge would be squeezed and pushed to the left. Similar to squeezing a slippery melon seed between fingers.
I don't think that helps with the question being asked, namely, how one is supposed to apply the method of virtual displacement here.
It's not a method I am au fait with, so I won't attempt to write an answer.
@Kashmir , see if page 31 onwards of https://www.worldscientific.com/doi/pdf/10.1142/9789810248154_0002 helps.
Likes aash nadeem and Kashmir
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
