I Virtual displacement is not consistent with constraints
Goldstein's 3rd edition has been criticized for its treatment of nonholonomic constraints, particularly regarding the consistency of virtual displacements with these constraints. The discussion highlights that while virtual displacements are defined as infinitesimal changes consistent with forces and constraints, they may not align with nonholonomic constraints at a given instant. The authors of the 3rd edition have acknowledged errors and retracted their flawed treatment online. Further clarification is provided by additional articles that confirm virtual displacements can contradict nonholonomic constraints, necessitating the use of Lagrange multipliers. Overall, the consensus is that the 2nd edition of Goldstein is preferable for accurate treatment of these concepts.
Kashmir
Goldstein 3rd ed says
"First consider holonomic constraints. When we derive Lagrange's equation from either Hamilton's or D'Alembert's principle, the holonomic constraint appear in the last step when the variations in the ##q_i## were considered independent of each other. However, the virtual displacements in the ##\delta q_{I}##'s may not be consistent with constraints. If there are ##n## variables and ##m## constraint equations ##f_\alpha## of the form Eq. (1.37), the extra virtual displacements are eliminated by the method of Lagrange undetermined multipliers.
I do not understand the parts that the virtual displacements may be inconsistent with constraints because earlier on in the book he defines virtual displacement as the infinitesimal change of the coordinates *consistent with the forces and constraints imposed on the system at the given instant ##t##* (pg 16).
Goldstein's 3rd edition is utterly flawed in the issue of nonholonomic constraints. Rather read the 2nd edition, which is correct! It's an example for a very good textbook ruined by people (obviously not by the original autor) who think they have to modernize it ;-)).
You precisely nailed the error in your last paragraph. Indeed the nonholonomic constraints are constraints on the virtual displacements (no matter whether you use the d'Alembert or the action principle, and it's at the given instant of time, and time is not to be varied).
For more details clarifying the issues with Goldstein's 3rd edition, see
https://doi.org/10.1119/1.1830501
As you can read there, in the meantime the authors of Goldstein's 3rd edition have retracted their errorneous treatment on a webpage:
http://astro.physics.sc.edu/Goldstein/
Thank you so much. I couldn't read the article in the journal and saw the errata. Could you please tell me are the virtual displacements consistent with the non holonomic constraints?
I found yet another article on arxiv that says that the virtual displacements can be in contrast with the constraints in non holonomic case. https://www.google.com/url?sa=t&sou...gQFnoECAMQAQ&usg=AOvVaw0RLIZuNZW0fswKBeqKr0o7
As far as I can see from glancing over the paper, there the statement about anholonomic constraints is correct (Fig. 1). It's a constraint on the "allowed" virtual displacements, which must be implemented by using Lagrange multipliers for the constraints in the form in the lower right corner of Fig. 1 to get the same correct equations of motion from Hamilton's principle in Lagrangian form as you get from d'Alembert's principle.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
