teroenza
- 195
- 5
I'm building an Arduino voltage logger that includes an op-amp (OP27G) as a buffer on the input. Since I'd like to be able to measure voltages all the way down to zero, I want to power the amp with a bipolar supply. My initial thought was to build the rail-splitter below so I wouldn't have to come up with two discreet (plus and minus) supplies.
http://www.goldpt.com/virtual_ground_circuit.html
My question is, if I power the OP27 with the virtual ground circuit above, then the voltage logger won't function correctly unless the voltage I'm trying to measure is also referenced to that virtual ground? I was hoping to use the logger to record voltages from various sources.
