I Virtual work and constraint forces
In a system of N particles with constraints, performing a virtual displacement on one particle can cause other particles to move in response. The inquiry focuses on calculating the virtual work done by constraint forces on all particles involved, questioning whether a non-zero result is possible for the work done on the single particle. The discussion references a book that states the total virtual work done by all particles must equal zero, in accordance with the principle of virtual work. However, it clarifies that the work done on an individual particle does not necessarily have to be zero. The principle emphasizes that while the net virtual work is zero, individual contributions may vary.
Ahmed1029
Suppose I'm considering a system of N particles that are constrained in their possible motions and so there are less that 3N generalized coordinates. Suppose now I perform a virtual displacement on one particle, which due to some constraints might force some other particles to more virtually with it, like the case of an atwood machine. I now want to calculate the virtual work done by the constraint forces on the particles that move as a corrolary to the movement of this single particle plus the work done on this particle itself, can I get a non-zero result? I'm asking because the book I'm reading assers that the virtual work done by virtually moving ALL the particles has to be zero, and not necessarily the work done to move a single particle has to be zero.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
