Virtual work in finite plane bending of Euler-Bernoulli beam
In summary: This allows us to accurately calculate the incremental rotation and strain at any point on a curved beam, even if the virtual displacements are only applied at a single point.In summary, the equations for incremental rotation and strain in a curved beam account for the effect of curvature on the virtual displacements by including additional terms that represent the curvature \frac{d\theta}{ds}. These terms act as correction factors to ensure accurate calculations of the rotational and strain behavior of the beam.
c0der
54
Please refer to the following image, which shows a portion of the deformed centerline of a beam in its equilibrium configuration with a uniformly distributed load.
The stress resultants are the axial forces T, transverse shears Q, and bending moments M at sections 1 and 2, with the rotations being relative to the horizontal.
We apply infinitesimal virtual displacements from the equilibrium configuration, with normal and tangential components [itex]\delta u_n[/itex] and [itex]\delta u_t[/itex] as functinos of arc length s.
If the beam were straight, then the incremental rotation is:
[itex]\delta \theta = \frac{d\delta u_n}{ds}[/itex]
And the incremental strain would be:
[itex]\delta \epsilon = \frac{d\delta u_t}{ds}[/itex]
I understand that part.
Now, given that the beam is not straight in its equilibrium position:
[itex]\delta \theta = \frac{d\delta u_n}{ds} + \frac{d\theta}{ds}\delta u_t[/itex]
[itex]\delta \epsilon = \frac{d\delta u_t}{ds} - \frac{d\theta}{ds}\delta u_n[/itex]
It's not intuitive for me how curvature multiplied by displacement gives the extra terms. How are they obtained?
The extra terms in the equations for incremental rotation and strain account for the effect of curvature on the displacement components. In a straight beam, the displacement components are solely determined by the virtual displacements \delta u_n and \delta u_t. However, in a curved beam, the virtual displacements are also influenced by the curvature of the beam, which is represented by \frac{d\theta}{ds}. This is because the curvature of the beam causes the virtual displacements to change as the arc length s changes.
To understand this better, let's consider a simple example. Imagine a straight beam with a small curvature at a specific point. If we apply a virtual displacement in the normal direction at that point, it will result in a small rotation, as expected. However, if we apply the same virtual displacement at a point with a larger curvature, the resulting rotation will be larger. This is because the curvature affects the rotation caused by the virtual displacement.
In the equations for incremental rotation and strain, the extra terms \frac{d\theta}{ds}\delta u_t and -\frac{d\theta}{ds}\delta u_n take into account the influence of curvature on the virtual displacements \delta u_t and \delta u_n, respectively. These terms can be thought of as correction factors that adjust the virtual displacements to account for the curvature of the beam.
Related to Virtual work in finite plane bending of Euler-Bernoulli beam
1. What is virtual work in finite plane bending of Euler-Bernoulli beam?
Virtual work is a method used in mechanics to analyze the equilibrium of a structure by considering the work done by virtual displacements that are consistent with the constraints of the structure. In finite plane bending of Euler-Bernoulli beam, virtual work is used to calculate the deflections and stresses in the beam under various loading conditions.
2. How is virtual work used in finite plane bending of Euler-Bernoulli beam?
In finite plane bending of Euler-Bernoulli beam, virtual work is used to calculate the deflections and stresses in the beam by considering the work done by virtual displacements. This method involves setting up equations of equilibrium and compatibility, and then using the principle of virtual work to solve for the unknown deflections and stresses.
3. What are the assumptions made in finite plane bending of Euler-Bernoulli beam?
There are several assumptions made in finite plane bending of Euler-Bernoulli beam, including: the beam is initially straight, the material is homogeneous and isotropic, the cross-sectional area remains constant throughout bending, and the beam is subjected to small deflections and strains.
4. What are the advantages of using virtual work in finite plane bending of Euler-Bernoulli beam?
There are several advantages to using virtual work in finite plane bending of Euler-Bernoulli beam, including: it allows for the calculation of deflections and stresses in complex structures, it is a versatile method that can be applied to different loading conditions, and it can provide accurate results when the assumptions are satisfied.
5. Are there any limitations to using virtual work in finite plane bending of Euler-Bernoulli beam?
Yes, there are some limitations to using virtual work in finite plane bending of Euler-Bernoulli beam. This method assumes that the beam is initially straight and subjected to small deflections and strains. If these assumptions are not satisfied, the results obtained from virtual work may not be accurate. Additionally, this method may become more complex when applied to more complex loading conditions.
10K
