Viscometer Question - calculating viscosity?
  • Thread starter veryc0nfused
  • Tags
    Viscosity
In summary, the velocity distribution of a fluid in two rotating cylinders is given by u=0.4/r-1000r (m/s). The diameter of the cylinders are 2cm and 4cm. If the inner cylinder rotates at 500rpm the power on the inner cylinder is measured to be 1Watt. The viscosity of the fluid is found to be -0.0191 using the torque and shear stress equations.
veryc0nfused
The velocity distribution of a fluid in two 0.3m long rotating cylinders is given by u=0.4/r-1000r (m/s). The diameter of the cylinders are 2cm and 4cm. If the inner cylinder rotates at 500rpm the power on the inner cylinder is measured to be 1Watt. Find the viscosity of the fluid?
P=τ . ω
Torque = μ x ((ω . R1)/(R1-R0))
So far my only attempt has been to converting the rpm and power output to find a torque value and then use this to find a viscosity, however, this brings me to a negative value?
torque = 1/52.36 = 0.0191
viscosity = (0.0191)(1-2)/1 = -0.0191
I also understand that the velocity distribution is not linear, however, do not understand how this works into finding the answer. Any help would be great! Thanks!
This is a very confusing problem statement. What does u represent? Is it an axial flow? What are the units of r in your equation for u? Your equation for the torque is incorrect. The equation you give for torque is really an approximation to the shear stress. You are correct in saying that the circumferential velocity distribution is not linear in the radius. To solve this problem, you first need to solve for the circumferential velocity distribution.
Yes, that's exactly what I thought. They haven't given any further information about the equation given only that it is for velocity distribution. However, from some research I believe that "u" is the tangential velocity and "r" is the location of the fluid within the gap between the two cylinders. What would my next step be?
If that is the case, then it doesn't seem consistent with the rotational speed of the inner cylinder of 500 rpm = 500 x 2π/60 radians/sec. If r is in meters, then I get zero velocity at the inner cylinder, and - 30 m/s at the outer cylinder (from the velocity equation). The actual velocity at the inner cylinder should be the radians/sec x 0.02 m. The velocity at the outer cylinder should be zero. The general form of the velocity equation seems correct, but the constants in the equation don't seem right. What do you think?
Chet
Yes, I agree.. The values given out by the velocity distribution do not seem to match with the specific situation of this question. The equation suggests that the distribution would be of parabolic nature with the velocity getting higher as it gets closer to the inner cylinder? Officially confused.
If you want, we can derive the correct equation for the velocity that is consistent with the stated boundary conditions. From the solution to the navier stokes equations, the form of the circumferential velocity as a function of radial position is going to be:
[tex]u=C_1r+\frac{C_2}{r}[/tex]
Use the stated boundary conditions to determine the constants C1 and C2.
The shear rate γ as a function of radial position is, for this situation, given by:
[tex]γ=r\frac{d\left(\frac{u}{r}\right)}{dr}[/tex]
and the shear stress is given by:
σ=ηγ
Once you know the shear stress at the inner cylinder, you can get the torque on the cylinder.
Chet
I have talked to my lecturer and he say's we shouldn't be changing the distribution formula.. Therefore, I was wondering if there is any way of doing this without using this equation?
Sure, by solving for the correct velocity distribution that satisfies the stated boundary conditions. This would be done starting with the circumferential component of the Navier-Stokes equations. This leads to a simple ODE for the velocity distribution. If you want to see the whole thing worked out in detail, see Transport Phenomena by Bird, Stewart, and Lightfoot, Example 3.6-3. See Eqn. 3.6-32. Also see Eqn. 3.6-31 for the torque in the case in which the outer cylinder is rotating, and the inner cylinder is fixed.
Chet
FAQ: Viscometer Question - calculating viscosity?
What is a viscometer?
A viscometer is a scientific instrument used to measure the viscosity of a fluid, which is a measure of its resistance to flow.
How does a viscometer work?
A viscometer typically works by measuring the time it takes for a fluid to flow through a small opening or tube. The longer it takes, the higher the viscosity of the fluid.
Why is it important to measure viscosity?
Viscosity is an important property of fluids, as it affects their flow and behavior. For example, high viscosity fluids are more resistant to flow and may require more energy to pump, while low viscosity fluids flow more easily and may be prone to leaking.
What factors can affect the accuracy of a viscometer reading?
The accuracy of a viscometer reading can be affected by factors such as temperature, pressure, and the type of fluid being measured. It is important to calibrate the viscometer and account for any potential sources of error.
How do you calculate viscosity using a viscometer?
The most common method for calculating viscosity using a viscometer is the Hagen-Poiseuille equation, which takes into account the dimensions of the viscometer and the time it takes for the fluid to flow through it. Other methods may also be used, depending on the type of viscometer and the properties of the fluid being measured.
