Viscosity as a function of temperature
In summary: I tested the equation you found for the line in your graph, and it was -2.229. This is the constant for the viscosity coefficient as a function of temperature of ethanol. In summary, the data points for the viscosity coefficient of ethanol suggest a linear relationship between temperature and viscosity, with a slope of -2.229.
MexChemE
237
55
Using the provided data for viscosity coefficients of C2H5OH (ethanol) as a function of temperature, find the constants A and B for this substance using the following equation.
Viscosity coefficients of ethanol:
T (K) - [itex]\eta[/itex] (cP)
273.15 - 1.773
293.15 - 1.2
313.15 - 0.834
333.15 - 0.592
[tex]\log \eta = \frac{A}{T} + B[/tex]
So, I start by plugging two sets of data into the equation in order to solve them algebraically:
[tex]\log (1.773) = \frac{A}{273.15} + B[/tex]
[tex]\log (1.2) = \frac{A}{293.15} + B[/tex]
I clear B from the first equation and plug it into the second equation:
[tex]B=0.248 - \frac{A}{273.15}[/tex]
[tex]0.079 = \frac{A}{293.15} + 0.248 - \frac{A}{273.15}[/tex]
Solve for A:
[tex]-0.169= \frac{273.15A-293.15A}{80073.922}[/tex]
[tex]-20A=-13532.492[/tex]
[tex]A=676.624[/tex]
Since I solved the second equation for A, I plug it into the first equation to solve for B:
[tex]0.248=2.477+B[/tex]
[tex]B=-2.229[/tex]
So, the viscosity coefficient as a function of temperature of ethanol is:
[tex]\log \eta_{{C_2} {H_5} {OH}} = \frac{676.624}{T}-2.229[/tex]
I tested the above formula and it yields very close results to those of the chart provided above for T=273.15 and T=293.15, but as I increase T the error gets bigger. I don't know if this is normal because I didn't use all the decimals, or I made a mistake in my math. Thanks in advance, PF! And sorry for the long post.
Well, you derived A and B using only the first two data points. Are you really surprised that these values of A and B may not be accurate for the other data points?
The fallacy in your method is that the relationship between temperature and viscosity is not linear. For a linear relationship, the slope of the line is the same no matter where your are on the line.
Trying to determine A and B, you should make a plot of your data. Can you draw a straight line or any other smooth curve which passes thru all the points, or must you try to adjust the curve so that it comes close to each point? If the latter, this is how you decide whether you need to do a regression analysis, so that you can produce the curve which has the 'best' fit (defined as the one which minimizes the error between the curve and the data points).
http://en.wikipedia.org/wiki/Regression_analysis
Relevant equations
logη=A/T+B
The equation is of the form
y = mx +b
from which, if the data points are plotted, and a straight line is obtained, it is trivial to determine m and b.
Plot a graph of ln(η) vs 1/T using all your data. Draw your best straight line. Determine the equation for the line to find A and B. The slope will be A.
Chet
My professor told us that the graph of logarithm of viscosity versus reciprocal temperature is indeed linear.
We're not supposed to use software yet, but I did give it a try, although it didn't help much. The only software I have access to right now is Excel, and it has no way to implement a reciprocal scale for T, not that I know, so the linear regression done by Excel was of no use for me.
I started over, now using T=273.15 and T=333.15. My results were a bit more closer this time. I was told this degree of uncertainty was okay for pencil and paper calculations, is that true? Thank you everybody for your responses!
Professors can tell you a lot of things, some of which may even be true. However, you go to school to learn how to think for yourself, and to acquire the tools and knowledge which allow you to verify whatever claims come your way.
You can analyze this data using Excel; you just haven't done it correctly. I've checked the log of the viscosity for the given data set (using both common and natural logs). It's close to a straight line, but not quite. Maybe close enough for government work, but that's about it. If you plot the data with the proper scale, you can remove all doubt.
FAQ: Viscosity as a function of temperature
What is viscosity?
Viscosity is a measure of a fluid's resistance to flow. It is a physical property that describes the internal friction of a fluid.
How does temperature affect viscosity?
Temperature has a significant impact on viscosity. In general, as temperature increases, viscosity decreases, and as temperature decreases, viscosity increases. This is because temperature affects the movement and interaction of molecules in a fluid, which in turn affects its internal friction and ability to flow.
Why is it important to understand the relationship between viscosity and temperature?
Understanding the relationship between viscosity and temperature is crucial in various industries, such as food and beverage, cosmetics, and oil and gas. Changes in viscosity can affect the quality and consistency of products, and can also impact the efficiency of processes and equipment.
How is the relationship between viscosity and temperature measured?
The relationship between viscosity and temperature is typically measured through experiments, where the viscosity of a fluid is measured at different temperatures. This data is then used to create a graph, known as a viscosity-temperature curve, which shows the exact relationship between the two variables.
What are some common applications of viscosity-temperature curves?
Viscosity-temperature curves are used in various industries to determine the appropriate temperature for a fluid to achieve a desired viscosity, to optimize process conditions, and to ensure product quality. They are also used in the development and testing of new products, as well as in troubleshooting issues with existing products or processes.
