Viscosity Problem using power law for non-Newtonian fluids
In summary, we can solve this problem by using linearization to find the values for η and n, and then plugging them into the power law equation to determine the viscosity of the blood sample. I hope this helps!
jetpacks
Problem Statement:
Blood is a pseudoplastic fluid that has a variable viscosity at 37 °C that depends on the percent composition of hematocrit and plasma. It will usually range between 3 x 10^-3 to 4 x 10^-3 Pa s. A small sample of blood is tested in a viscometer and the following results are obtained:
(Shear stress (Pa), Shear rate (s^-1))
(0.0235, 2.25)
(0.0396, 4.5)
(0.0787, 11.25)
(0.1324, 22.5)
(0.2227, 45)
(0.3746, 90)
(0.7447, 225)
(1.2524, 450)
Determine the viscosity of the blood sample using the power law for non-Newtonian fluids:
τ=ηγ^n
where τ is shear stress, η is viscosity, γ is shear rate, and n is the flow behavior index.
_____
I have no idea where to start, since I have two unknowns in this problem. It also seems like the sample would have a different viscosity at each point, but the problem only asks for one value. I am truly lost. Any help or insight would be greatly appreciated!
Hi there, thank you for bringing this problem to our attention. it is important to be able to analyze and interpret data, especially when it comes to fluid mechanics. Let's break down the problem step by step to help you understand and solve it.
First, let's define the variables in the power law equation. As mentioned, τ is the shear stress, η is the viscosity, γ is the shear rate, and n is the flow behavior index. We also know the values for shear stress and shear rate from the data provided. So, we can rewrite the equation as:
0.0235 = η(2.25)^n
0.0396 = η(4.5)^n
0.0787 = η(11.25)^n
0.1324 = η(22.5)^n
0.2227 = η(45)^n
0.3746 = η(90)^n
0.7447 = η(225)^n
1.2524 = η(450)^n
Now, we have eight equations with two unknowns (η and n). To solve this, we can use a method called linearization. We will take the natural log of both sides of the equation to get:
ln(0.0235) = ln(η) + n*ln(2.25)
ln(0.0396) = ln(η) + n*ln(4.5)
ln(0.0787) = ln(η) + n*ln(11.25)
ln(0.1324) = ln(η) + n*ln(22.5)
ln(0.2227) = ln(η) + n*ln(45)
ln(0.3746) = ln(η) + n*ln(90)
ln(0.7447) = ln(η) + n*ln(225)
ln(1.2524) = ln(η) + n*ln(450)
Now, we can treat this as a linear equation with two unknowns (ln(η) and n). We can use any method to solve this, such as substitution or elimination. Once we have the values for ln(η) and n, we can take the antilog to get the values for η and n.
Once we have
Related to Viscosity Problem using power law for non-Newtonian fluids
What is viscosity?
Viscosity is a measure of a fluid's resistance to flow. It is often described as the "thickness" of a fluid, with higher viscosity fluids being thicker and more resistant to flow than lower viscosity fluids.
What are non-Newtonian fluids?
Non-Newtonian fluids are fluids that do not follow the traditional Newtonian model of viscosity, where the viscosity is independent of the shear rate. These fluids exhibit more complex relationships between shear rate and viscosity, such as shear-thinning or shear-thickening behavior.
What is the power law model?
The power law model is a mathematical model used to describe the relationship between shear stress and shear rate in non-Newtonian fluids. It is based on the power law equation, where the shear stress is proportional to the shear rate raised to a power.
How is the power law model used to solve viscosity problems?
The power law model is used to calculate the viscosity of a non-Newtonian fluid at a given shear rate. This can be useful for predicting how the fluid will behave in different situations, such as in industrial processes or in the human body.
What are some real-world applications of the power law model for non-Newtonian fluids?
The power law model has many practical applications, including in the food industry for understanding the flow of liquids such as ketchup or mayonnaise, in the pharmaceutical industry for predicting the behavior of suspensions and emulsions, and in geology for studying the flow of magma and lava.
  • General Engineering
