I Visibility when looking down through a Glass Bottom Boat
  • I
  • Thread starter Thread starter gutman
    Glass Underwater
Visibility through a glass bottom boat is superior to looking over the side due to the reduction of optical disturbances caused by the water's surface. The non-flat surface of the water bends light randomly, distorting images, while a flat glass surface provides a clearer view. Additionally, reflections from the brighter sky can wash out underwater visibility when looking directly into the water. Glass bottom boats often feature dim interiors to minimize reflections and enhance viewing conditions. Overall, these factors combine to create a more optimal underwater viewing experience.
gutman
TL;DR Summary
Why is there better visibilty when viewing under water through a glass bottom of a boat rather than say looking over the side of the boat?
Science news on Phys.org
Welcome to PF.
What are your thoughts on this question? Have you been able to find anything with your Google searching so far? How familiar are you with the index of refraction of clear materials?
The only reference I could find is on Wikipedia "glass-bottom boat", where it says "The view through the glass bottom is better than simply looking into the water from above, because one does not have to look through optically erratic surface disturbances.". That was my intuition as well, but I'd like to go beyond imtuition... I hope to get some support (or not) for this claim, and more details.
The non-flat surface of the sea means that light paths bend randomly at the surface, distorting images seen through it. You can see this effect in a swimming pool, or even a bowl of water.
Additionally, the sky above you is brighter than the sea below, so you see a lot of light from above washing out what's inside. It's much like looking into a window from outside on a sunny day - you see the exterior world reflected and not much of inside. When you're in a viewing boat the interior will be dim so you don't see so much reflection.
Likes gutman, Gleb1964 and berkeman
gutman said:
TL;DR Summary: Why is there better visibilty when viewing under water through a glass bottom of a boat rather than say looking over the side of the boat?
Light from the sky (and particularly the Sun, of course) will reflect at the surface of water or glass. For a water surface, with many wavelets, wherever you look on the surface, you can see moving spots of light from which will all 'sparkle' annoyngly. Working under a tent or sunshade wil eliminate most of that. A crinkly water surface will produce specular reflections in many directions (distorting the image due to refraction at the changing surfaces but a plane glass surface will only show one image of the Sun and you can easily move your viewing point to put that image somewhere it doesn't matter.
Glass bottomed boats for tourists usually have a small cabin to reduce significant light interference.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
