Visualising visible light Fluorescence
In summary, "Visualising visible light Fluorescence" explores the phenomenon of fluorescence, where certain materials absorb light and re-emit it at longer wavelengths. The process is illustrated through various applications in science and technology, highlighting its importance in fields like biology, chemistry, and environmental monitoring. The visualization techniques used to observe fluorescence, such as microscopy and spectroscopy, are discussed, showcasing how they enhance our understanding of molecular behaviors and interactions. The article emphasizes the role of fluorescence in advancing research and practical applications across different disciplines.
aaaaautumn
Hi all,
I am new to physics forum and would appreciate all your input in this topic. I am trying to understand if an object fluoresces under UV light it is possible it may also Fluoresce under visible light? additionally would it be possible using band-pass filters (device that passes frequencies within a certain range and attenuates frequencies outside that range) to narrow the band of visible light and observe this fluorescence?
I am a physician and not a physicist so do excuse my ignorance if Im talking rubbish :)
Yes and yes. We are more accustomed to fluorescence from the UV into the visible because it is an obvious phenomenon, but fluorescence from the visible to the visible can occur, but it is usually harder to distinguish from the object being a certain color. Using filters would be one way to observe this fluorescence.
Likes vanhees71 and Orodruin
And why not from visible to non visible frequencies? All that's required is appropriate energy levels in a substance. When light of a certain frequency is 'absorbed' by a pigment then the energy can be at an IR frequency. Some light is absorbed and produces a colour by frequency selective reflection.
I suggest that fluorescence is actually a special case which makes certain surfaces look odd or noticeable under the right lighting conditions. What you see in other situations could often be due to a similar mechanism.
On photon energy grounds, the excitation light must have a shorter wavelength than the emitted light. That limits the excitation when it comes to visible - visible fluorescence. A blue light can excite a red fluorescent emission, but not the other way around.
There are only a handful of "Dayglo" or "dayglow" pigments that fluoresce in the visible under UV light.
Likes DrClaude
thank you @DrClaude @Baluncore @sophiecentaur
If I can be more specific I am conducting research on composite resin which is used in dentistry. In UV light (sweet spot of 385nm) it fluoresces and can be seen in the visible blues spectrum, this allows us to identify what is composite from what is say tooth structure when performing procedures. However UV light is something we try to limit using in healthcare due to adverse effects on the skin and cancer risk, I am trying to figure out if I can use visible light instead of UV and then use a relevant band pass filter to obverse its fluorescence. Is this a crazy idea? is there a process by which you can find out if an object fluoresces in visible light and the wavelength that fluorescence is most visible at? Any other ideas using the same concepts is very welcome and would heavily aid in my research project.
Thanks again
Firstly I'd suggest that the original dose of UV that cured the resin (several seconds of exposure there) would need to be many times the dose needed to see some fluorescence. So probably no worries if you read up the Health and Safety situation in the use of the uv setting resin. And the uv source could be a lot less bright.
As for finding an alternative light source for the effect, I'd imagine that you won't find a lower frequency that would cause actual fluorescence. For a start, the frequency shift is very small if the colour you get is blue. But the same frequency that is produced by fluorescence is likely to be a similar frequency that would be absorbed when used as an illumination. A spectrometer could measure a specific visible band and that could spot the presence or absence of that resin. Hand held spectrometers are used by gemnologists to determine the chemicals that are responsible for some gem colours. Somewhere for you to look, perhaps.
Blue fluorescence really has you cornered at the violet end of the spectrum. To get blue, you must excite the composite resin with a shorter wavelength, UV or violet. The boundary between near-UV and visible-violet, is usually taken to be the wavelength of 380 nm. Your "sweet spot", of 385 nm, is strictly visible-violet, NOT ultra-violet, UV.
https://en.wikipedia.org/wiki/Violet_(color)
A white LED lamp is typically made from a violet LED emitter, with several visual fluorescent compounds, balanced to make a daylight white, or a warm white light. You might be able to use a violet LED as your excitation source, to emit blue light.
LED sources of 395 nm are cheap, and widely available. They often claim to be UV or "black light" in the advertising, but they are not, they are violet. Have you tried one of those?
An example, used to fluoresce blue is; https://www.ebay.com.au/itm/295950654406
Note that "grow lights", used for hydroponics, could employ a violet LED, but they may actually be purple=blue+red, which is useless for blue fluorescence.
https://en.wikipedia.org/wiki/Grow_light#Fourth_generation:_Light_emitting_diodes_(LEDs)
FAQ: Visualising visible light Fluorescence
What is visible light fluorescence?
Visible light fluorescence is the emission of light by a substance that has absorbed light or other electromagnetic radiation. It occurs when molecules absorb photons at one wavelength and then emit photons at a longer wavelength, which is visible to the human eye.
How is visible light fluorescence different from phosphorescence?
While both fluorescence and phosphorescence involve the absorption of light and the subsequent emission of light, the key difference lies in the time scale. Fluorescence occurs almost instantaneously, usually within nanoseconds, whereas phosphorescence can last from microseconds to minutes or even hours after the excitation source is removed.
What are common applications of visible light fluorescence?
Visible light fluorescence is widely used in various fields including biological imaging, chemical sensing, medical diagnostics, and material science. Examples include fluorescence microscopy for observing cellular structures, fluorescent dyes for tagging molecules, and fluorescent sensors for detecting environmental pollutants.
What types of materials exhibit visible light fluorescence?
Many types of materials can exhibit visible light fluorescence, including organic compounds like fluorescein and rhodamine, inorganic compounds like quantum dots, and biological molecules like proteins and nucleic acids. Synthetic materials like certain polymers and nanomaterials also exhibit fluorescence.
How can visible light fluorescence be measured and visualized?
Visible light fluorescence can be measured and visualized using instruments such as fluorescence microscopes, spectrofluorometers, and fluorescence scanners. These devices detect the emitted light and can produce detailed images or spectra that reveal the presence and concentration of fluorescent substances.
